Ricky Brown
Posted: Tue Dec 18, 2012 4:35 am Post subject: wf carb |
| Any tips on the wf carbs? Do's and dont's etc? |
Craig Drabik
Joined: 09 Jun 2009 Posts: 73 Location: United States, New York, Buffalo
Posted: Tue Dec 18, 2012 10:50 am Post subject: |
| Keep it clean, start at the factory settings, and generally leave it alone. The thing just runs. |
Ricky Brown
Posted: Tue Dec 18, 2012 2:34 pm Post subject: carb |
| Jetting/ needle placement? You don't tend to change any of it? Is there a tool to check the float level? |
Bernie Lacotta
Posted: Tue Dec 18, 2012 3:15 pm Post subject: Re: carb |
| Ricky Brown wrote: | | Jetting/ needle placement? You don't tend to change any of it? Is there a tool to check the float level? |
Go to www.fastermotors.net ,Jimbo has anything,including info that you may need. By the way I rarely change jets. _________________ I breathe ,therefore,I race |
George Vorrilas
Joined: 11 Feb 2007 Posts: 228 Location: United States, Massachusetts,
Posted: Sun Dec 23, 2012 12:55 pm Post subject: WF Carburator |
Rick, regarding the World Formula carb. Again, we ran 14 of the WF's on set and our only changes were in the needle position. Of the 14 we ran, we didn't change a single jet, just needle position to richen them up. Keep in mind that the kart chassis we manufactured ran a flat mount. If you get into the 12-15 degree mounts you may need to make a slight adjustment to the float level. My suggestion regarding the fuel system, use a quality filter, and we run only race fuel as we have had horrid experiences with pump fuel.
Keep in mind that the World Formula is a real fuel miser and will run all weekend on a gallon or two so the fuel budget with race gas is not as big of an issue as it is with some of the more exotic stuff.
Now stop tinkering, your kart won every race it was entered in last season... Get in, step on gas..
As always, feel free to give us a call or stop by the shop . Thanks George V.
ApexKartSports
978-479-7974 |
George Vorrilas
Posted: Sun Dec 23, 2012 12:56 pm Post subject: WF Carb |
ApexKartSports
978-479-7974 |
Ricky Brown
Posted: Mon Dec 24, 2012 4:34 am Post subject: |
| Awesome answer George! |
al nunley
Posted: Mon Dec 24, 2012 10:44 am Post subject: |
This all may be true if you just want to play around, meaning not racing, but if you want to race, and win, there’s a lot more to it.
Air density changes, sometimes a lot, and the EGT should be observed to make sure the mixture is at optimum. _________________ If the data does not support the theory, get a new theory. (Al Nunley)
David McDowell
Joined: 01 Oct 2011 Posts: 58 Location: United States, California, Mt Shasta
Posted: Tue Jan 08, 2013 2:55 pm Post subject: |
Al,
It would be great to watch the EGT but you cant have a port per IKF. |
