SKUSA (non-flash) - LB
MRP - SS
Picture of the new VM KZ engine
Goto page 1, 2  Next
Tore Pedersen
PostPosted: Mon Dec 17, 2012 9:48 am    Post subject: Picture of the new VM KZ engine Reply with quote
Here is a link to the new VM KZ engine for those who are interested.
https://www.facebook.com/media/set/?set=a.403160283097025.97542.122628667816856&type=1
Jim Maxson
PostPosted: Mon Dec 17, 2012 2:55 pm    Post subject: Reply with quote
Very Nice stuff
Tore Pedersen
PostPosted: Mon Dec 17, 2012 3:26 pm    Post subject: Reply with quote
Jim Maxson wrote:
Very Nice stuff
Yes, and fast to Smile
Charles Kaneb
PostPosted: Mon Dec 17, 2012 4:30 pm    Post subject: Reply with quote
Looks nice; but you can't actually get parts from them.
"If you're still in full control, you're not going fast enough" - Fred Frame
Keith Bridgeman
PostPosted: Mon Dec 17, 2012 5:48 pm    Post subject: Reply with quote
Yeah, maybe the least represented engine in america.
The new LKE engine is being built with Tec Sav as a partnership, thats kind of interesting.
Merlin / Maxter KZ
Tore Pedersen
PostPosted: Tue Dec 18, 2012 12:57 am    Post subject: Reply with quote
I have parts, what do u need?
Jim McMahon
PostPosted: Tue Dec 18, 2012 7:26 am    Post subject: Reply with quote
Tore can you post a link to the homologation sheets if that's been done yet?
Tore Pedersen
PostPosted: Tue Dec 18, 2012 7:31 am    Post subject: Reply with quote
Hi. Here are homologation sheets for both engine, and also the latest stage 3 upgraded reed cage with short intake.
http://mach1motorsport.files.wordpress.com/2012/03/homologering-vm.pdf
http://mach1motorsport.files.wordpress.com/2012/03/ny-reed-homologering.pdf
Jim McMahon
PostPosted: Tue Dec 18, 2012 7:46 am    Post subject: Reply with quote
Thanks Tore. Here's a parts breakdown too:
http://www.mskart.cz/new/files/u1/motory/vm125eng.pdf
Jim McMahon
PostPosted: Tue Dec 18, 2012 8:58 am    Post subject: Reply with quote
Drool...
http://www.vmmotor.com/motokarove-motory/motor-vm-250-m01/technicka-data-vm-250-m01.html
Tore Pedersen
PostPosted: Tue Dec 18, 2012 9:40 am    Post subject: VM motor Reply with quote
That is the old side by side superkart, still selling. The new homologation will be an inline engine. Hopefully the homologation sheets will be revealed January.
mal crosher
PostPosted: Tue Dec 18, 2012 9:45 am    Post subject: Reply with quote
I just noticed drive sprocket is out board.
Jim McMahon
PostPosted: Tue Dec 18, 2012 10:00 am    Post subject: Re: VM motor Reply with quote
Powervalves or no?
Tore Pedersen
PostPosted: Tue Dec 18, 2012 10:06 am    Post subject: Re: VM motor Reply with quote
Powervalves or no?
The buyer decides, its slightly cheaper without.
Jim McMahon
PostPosted: Tue Dec 18, 2012 1:27 pm    Post subject: Reply with quote
Its not gonna be like hitting up the local GM dealer for something for your 3800 or whatever but its rarely as bad as people make out. Most of the moving parts in KZ motors are highly interchangeable.
54mm piston
Seals
110mm or 108mm Conrod (110 in this one)
Top, bottom and main bearings prettymuch the same across the board.
Clutch plates are pretty common.
Transmission parts might be a bit tricky but I've yet to come across anyone who has actually damaged any in a KZ. I'm not suggesting it has never happened, i'm sure it has but it's not common.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.120636 (35.68%), total time:0.338078, queries:38
