MIR Racewear - LB
RLV - SS
MMX gear choice
Adam Blevins
PostPosted: Wed Dec 12, 2012 7:58 pm    Post subject: MMX gear choice Reply with quote
Anyone who has run at Mooresville want to share what gear set was working for them?[/img]
Eric Alexander
PostPosted: Fri Dec 14, 2012 10:31 am    Post subject: Reply with quote
I've only shaken down my karts there since renting a garage so this is just a starting point. I ran 12-82 on both and was hitting 13,000 rpms. The track is very smooth and I was on two-session old Bridgestone YKCs - so there is more grip to be found which may or may not impact the gearing. I think with more mechanical grip the gearing would be very good... maybe a tooth or two either way depending on weather.
Ihor Bilyy
PostPosted: Fri Dec 14, 2012 9:44 pm    Post subject: Reply with quote
We did 4 sessions, all with different gears in Rotax Jr.
Started with 12/76, ended with 13/75. The best lap was with 13/75 (51.2), but a lot more time on track would tell what is the gear choice, as that was my son first time on track.
Juniors, in average, 4-5 teeth from Masters. As you can see, it is very different from 12/82. You will find yours when you test.
edit: 2 race weekends old Mojo D2 tires
Adam Blevins
PostPosted: Sat Dec 15, 2012 10:32 am    Post subject: Reply with quote
Thanks for the heads-up. I've got a good starting point.
DB time: 0.14281 (54.26%), total time:0.263201, queries:38
