SoCal Sprinters
Jetting chart for CR125 with PWM pump around
Goto page 1, 2  Next
Aaron Bunch
PostPosted: Mon Dec 10, 2012 4:20 pm    Post subject: Jetting chart for CR125 with PWM pump around Reply with quote
Does anyone have a jetting chart they would be willing to share? I have had an awful time with jetting and it seems like my instincts are always backwards or I am just plagued with bad luck.
It was in the mid 50's yesterday and I was running a 175 main and a 52 pilot...and I melted a piston. Our altitude here is about 750 feet and yesterday's barometric pressure was about 29.9
The highest EGT I registered was ~1230F. I really didn't think I was in danger...and then I had no compression....
I have an SRS motor, but I bought the kart that way so I am a little reluctant to bother John with my questions because I am not directly a customer of his.
Aaron
Sam Zavaglia
PostPosted: Mon Dec 10, 2012 6:23 pm    Post subject: Reply with quote
I'm guessing you can't melt a piston on tune with a 175/52 if it is Stock CR125 cylinder/base gasket/head/head gasket/OEM piston/'99 ignition, assuming your fuel is 98 or higher and fresh, so in which case it must be a mod engine somewhere, hence get a engine tuner to look at it front to back if that's the way you got it and not opened it up.
Also assuming your running a suitable needle, lots of assumptions here, you know what that means.......
Otherwise there must be a problem with water flow through the engine or something wrong if it is complete stock and setup to spec Honda.
www.samzavaglia.com
Jimmy McNeil
PostPosted: Mon Dec 10, 2012 6:39 pm    Post subject: Reply with quote
Pilots to lean. Depending on how long you are wide open on the straight, the main mite be close.
What needle you running?
I guess I should say, that would be to lean on my Swedetech stock honda.
Sam Zavaglia
PostPosted: Mon Dec 10, 2012 9:40 pm    Post subject: Reply with quote
I thought that too Jimmy but it depends how long the straight is. Then comes the the actual meaning of "Melting" the piston. I wouldn't consider a seize "melting" the piston, we don't know which one it is.
Can make so many assumptions with all the unknowns.
Take it to the same engine builder if modded, or any other engine builder of choice/convenience is it's Spec Honda.
www.samzavaglia.com
Bill Pyles
PostPosted: Tue Dec 25, 2012 6:21 pm    Post subject: CR125 jetting with PWM/pump-around Reply with quote
Personally, I would get rid of the pump-around, and opt for what many refer to as a "hybrid set-up" which uses a double pump, but retains the floats in the bowl.
For the ambient conditions you describe, I would start with a 55 pilot and 185 main and look at your lap times and plug and lean the main from there. You will probably end up with a 180 or 178, but leave the pilot at 55.
Bill Pyles
Phoenix AZ
Oscar Aguilera
PostPosted: Wed Dec 26, 2012 7:20 pm    Post subject: Reply with quote
call john...dont listen to us yo yos any more than you have to! lol
john is a really nice guy and he will help you no matter what,,,,if you ask.
first thing that comes to my mind is....was the radiator covered and motor running at 120-130 F? i dont leave the grid with anything less than 110, but if the rad is not covered the motor/water will cool down to much.
you may have cold siezed it....dont think you would have seized it with that jetting. other than it might not have run great on standing starts???? it should have run.
the only other thing is pump gas? you may have detonated the piston,,,it chipped/cracked and got into the head or cylinder.
chances are if it stuck in the first 5 laps it cold siezed...in that weather you would have had to do at least 5 laps to get heat in the tires to go fast enough to hold it wide open long enough for you to stick it from being too lean.
if you were up on water temp and all the above was correct....you were on a road race course? then you were too lean! you need to be 2 jets bigger than what jet you would run on a sprint race in the same conditions when it is that cold especially
just my opinion
al nunley
PostPosted: Thu Dec 27, 2012 8:06 am    Post subject: Re: Jetting chart for CR125 with PWM pump around Reply with quote
Aaron
The EGT sounds good, but were you watching it very close? And off the turns, because the 2 cycle will need a richer mixture on the low speed and can get lean there too. Watch it off the turns. The temp will be lower, because it needs to be. Detonation is caused by excessive heat and/or pressure. On the low end, where the engine reaches peak torque, and ports and pipe are at their most efficient point, both of those will be at their highest.
Many think it’s lower there because it’s just starting out, not true,
On the high speed, where the pipe and the porting become less efficient, and the pressures go down, the mixture can be leaner, and the EGT will read higher.
I have a jetting spreadsheet, (Excel) that might do it for you. Send me some typical jet sizes for that engine and I’ll see if it works. I’ve been using it for Briggs engines.
You can compare two different jet sizes for the percentage difference between them.
Sounds to me like you need an air density gauge. The very best way to set jetting. A compression tester would help too.
Comments, Compliments, Questions and Criticisms, write Al Nunley @ anunley@austin.rr.com
Mike Goebel
PostPosted: Thu Dec 27, 2012 9:59 am    Post subject: Re: Jetting chart for CR125 with PWM pump around Reply with quote
Aaron
Call DDR, they love to answer phone questions regardless of engine builder.
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Alex King
PostPosted: Thu Dec 27, 2012 4:10 pm    Post subject: Re: Jetting chart for CR125 with PWM pump around Reply with quote
Phone/FAX/Mail/Email - see below:
Phone or FAX Mailing Address
(805) 933-2616 Phone
(805) 933-2659 FAX
Darcy DeCoste Racing
333 South 11th Street
Santa Paula, CA 93060
Email Darcy
info@DarcyDeCosteRacing.com
Mike Goebel wrote:
Aaron
Mike G.
Aaron Bunch
PostPosted: Fri Dec 28, 2012 3:09 pm    Post subject: Reply with quote
Thanks for the replies and advice.
I have a theory.....
I think my fuel pump wasn't working well enough to keep the bowl full. On the tighter part of the track I am off the gas enough that the pump can keep up, but when I get on the longest straight the bowl gets sucked dry.
I have the Shark Shifter bracket that mounts the fuel pump to the motor:
http://sharkshifter.com/zc/index.php?main_page=product_info&cPath=20&products_id=219&zenid=5355254db0801f14a0667c7b028042b5
The previous owner installed the pumps upside down so that the pulse line was on top. This prevented the vacuum/pulse chamber in the pumps from self draining. So my pumps had quite a bit of oil in them. I should have seen this and I should have taken more care to clean the pumps.
My bracket design has been changed, and now has the pulse line on bottom where it can easily self-drain into the cases. Plus I rebuilt the feed pump just to be sure.
I don't think I mentioned it in the first post, but at one point I did manage to grab the choke while it was acting up..my theory was that if it was too lean then the choke would add fuel and it might run right...it didn't...but if the bowl had been sucked dry by that point then pulling the choke would not have helped anyway.
So that's my theory, it makes sense to me at least, haha. I replaced the piston, honed the cylinder and reassembled it all. I haven't been to the track again since (because of holidays plus weather).
Thanks again,
Aaron
Jimmy McNeil
PostPosted: Fri Dec 28, 2012 5:35 pm    Post subject: Reply with quote
Aaron, fatten up your mid range. If you fatten it up and its to rich, you can always lean it back down. If you leave it and its to lean, you will stick it again.
BTW Ive raced at over 6000ft and the lowest I get on my mid range is a 55. No reason to ever run a 52 at you elevation.
My home track is also around 700ft when the temp is in the 50's. I would run a 180 main and a 58/60 pilot.
marc-andre hubert
PostPosted: Sun Dec 30, 2012 8:27 am    Post subject: Reply with quote
in Florida with high 60 mid 70f i run 55 main 180 and runs great top 1250 mid 900egt runs strong and clean and plug still looks a bit rich
Jason Berry
Advertiser
Advertiser
PostPosted: Fri Jan 04, 2013 10:42 am    Post subject: Reply with quote
Are you using pump fuel?
www.shopswedetech.com
www.swedetechracing.com
www.swedetechracing.com/news-events-blog/
www.facebook.com/Swedetech
Jason Berry
Advertiser
Advertiser
PostPosted: Fri Jan 04, 2013 11:21 am    Post subject: Reply with quote
If you are using pump fuel, change it to VP MS 98 with Motul Kart Grand Prix. Also, if this is a used kart, inspect the silencer for a broken core or blocked exhaust.
Once you have a good base line with fuel and the mechanics, this jet chart may help you.
http://www.swedetechracing.com/news-events-blog/swedetech-technical-help/how-to-create-a-jet-chart/
J.R. Clasen
PostPosted: Fri Jan 04, 2013 12:35 pm    Post subject: Tuning Reply with quote
You might want to consider that you 'cold seized' the engine. What temp did you get up to before going on track, and how much tape did you keep on the radiator?
JR Claesn
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.395513 (57.91%), total time:0.683016, queries:38
