Hector Fernandez
Joined: 25 Oct 2012 Posts: 49 Location: United States, Florida, Daytona
Posted: Thu Dec 06, 2012 4:59 pm Post subject: DD2 case damage?? |
What do you guys think can this be repaired?? Without opening it
Thoughts opinions?. |
Martin Colligan
Joined: 30 Sep 2012 Posts: 30 Location: United States, Alabama,
Posted: Thu Dec 06, 2012 8:00 pm Post subject: |
I had one repaired ... yours looks better then mine.
Pretty sure it can be repaired but the problem would be to make sure everything is ligned up ...
( sorry for my english i speak french ! ) |
Hector Fernandez
Posted: Fri Dec 07, 2012 7:19 am Post subject: |
Martin how did the repair hold out?? Who did your repair kart shop or machine shop?. Did you have to split the cases??
Thanks in advance |
Martin Colligan
Posted: Fri Dec 07, 2012 7:34 am Post subject: |
Mine had to be split but it was because the actual base cracked and was leaking ...
From what I see it seems like it could possibly be repaired without splitting the case.
Good luck ! |
Posted: Fri Dec 07, 2012 9:31 am Post subject: |
I think it's doable if it's well thought out. The problem is not cooking the near by gaskets and seals. I would clean it all up then figure out some sort of dam or block a system where water could be sprayed on the material out of the weld zone without interfering with the welding process.
Brian |
