SKUSA (non-flash) - LB
K1 Speed - SS
Franklin / Merlin USA - FB
Leopard 8 Pole Terminal Connector
Aamir Hyder
PostPosted: Thu Dec 06, 2012 2:42 pm    Post subject: Leopard 8 Pole Terminal Connector Reply with quote
Has anyone had to replace the 8 Pole Terminal Connector on their Leopard Key Start engine? It is on the wiring harness that comes out of the bottom of the iginition. I found one at AutoZone (link below) but I was wondering if anyone has any better suggestions?
http://www.autozone.com/autozone/accessories/MSD-8-pin-Deutsch-weatherproof-connector/_/N-269d?itemIdentifier=224530_0_0_
Jim Russell, Jr.
Advertiser
Advertiser
PostPosted: Fri Dec 07, 2012 7:01 am    Post subject: Reply with quote
We have this connector and any connector on the wiring system in stock. Also available at any IAME dealer.
http://storefront.russellkarting.com:8080/storefrontCommerce/search.do?searchType=itemNumber&keyword=ia-ife-050&emailAddress=&numResults=50
Russell Karting
888-KARTING
Mike Martz
PostPosted: Sun Dec 09, 2012 8:39 am    Post subject: Reply with quote
Jim,
Don't you need a tool to get the pins out of the connector? If so, do you have that tool? I have the same connector with one bad pin and it is good to see you have the connectors.
Mike Martz
Kevin Martz - Driver of the #199 Safety-Kleen, Bell Helmets, Rapid Racing Top Kart / Leopard
www.motorsportsliquidators.com
Rapid Racing - www.rapidracing.com
Jim Russell, Jr.
Advertiser
Advertiser
PostPosted: Mon Dec 10, 2012 7:55 am    Post subject: Reply with quote
It is designed to go onto fresh wire and lug. We have picked out a bad pin before with a pick. But 75% of the time we damage the connector and have to cut it off and start over.
Russell Karting
888-KARTING
Aamir Hyder
PostPosted: Mon Dec 10, 2012 8:41 am    Post subject: Reply with quote
Thanks Jim!
DB time: 0.126427 (38.52%), total time:0.328239, queries:38
