Ocala Gran Prix - LB
Russell Karting - SS
Evans Coolant
Goto page 1, 2  Next
PostPosted: Thu Dec 06, 2012 8:44 am    Post subject: Evans Coolant Reply with quote
Anyone using this? http://www.evanscooling.com/products/coolants/powersports-coolant/
PostPosted: Thu Dec 06, 2012 10:45 am    Post subject: Reply with quote
Not to rain on your parade, but every org I ever ran with bikes, cars, karts, state water only in the cooling system, and you may add water wetter type product. This product has no water in it. It could be a great product, but you would have to see if there's anything slippery in it, and "IF" you can get it approved for use on the track.
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Roger Miller
Site Admin
PostPosted: Thu Dec 06, 2012 11:29 am    Post subject: Reply with quote
They have some reports posted on the home page and the DeTox report is all about Ethylene Glycol and Propylene Glycol, so this wouldn't be allowed in any karting sanction that I am aware of.
PostPosted: Thu Dec 06, 2012 11:39 am    Post subject: Reply with quote
CR
You love raining on my parade LOL
PostPosted: Thu Dec 06, 2012 7:18 pm    Post subject: Reply with quote
CR
Actually not, that was a good find, too bad it won't work for our application. That would work fine on a motocross, or woods bike....
CR
joseph hollinger
PostPosted: Thu Dec 06, 2012 11:31 pm    Post subject: Reply with quote
CR
CR
It's really hard to imagine why it would work. I mean, I'm just working from memory but my understanding is that the specific heat capacity of water is about 3X of glycol.
PostPosted: Fri Dec 07, 2012 5:29 am    Post subject: Reply with quote
I don't understand how it works either but the Motocross guys use it and claim it drops the temp 25-40 more than water.
PostPosted: Fri Dec 07, 2012 11:18 am    Post subject: Reply with quote
That's a pretty big claim, peggs my BS meter for sure.
Their website claims that the coolant won't overheat, what exactly does that mean? If it means that it won't vaporize at any temperature what happens when it gets above the melting point of aluminum?
It might be the best product ever but at ~ $105 more than distilled water I don't think I'm gonna test it out any time soon Shocked
Redline has been making waterweter for a long time and it's accepted by most racing orgs so if there were some kind of magic out there I'll bet their chemists would have it on the market by now.
Reality is that engineers design cooling systems to work with H20 since it's available everywhere and has known properties. Remember, cooler is better only up to a certain point. Your engine needs to get up to temp to make max power so cooling 40 degrees below normal operating temp will hurt performance. If you're running 40 degrees above recommended temp you should check your mixture and/or timing.
It's pretty easy to get your buddies to go onto a forum and make claims that you don't have to back up, not that that's what's happening here but maybe on the motox forum?
Cheers,
Heartbeat Power, LLC.
Andre Eriksen
PostPosted: Fri Dec 07, 2012 12:44 pm    Post subject: Reply with quote
In the company I work for, we ship more than 40,000 liquid cooling systems a month. They are actually pretty similar to a kart setup in the sense there is an aluminum radiator, a pump and some rubber tubes (on a side note, we get screwed on the radiator cost! A Rotax style radiator costs $10 - $15 in China, I know because we buy half a million a year out there).
We have invested a lot of money in custom engineered fluids over time as what we make a living of is selling cooling performance and hence the better heat transfer in the liquid can turn in to $$$ for us. Our thermal engineers in both Europe and US have tested countless fluids and mixes.
As our systems are shipped world wide and on airplanes we need to have antifreeze and glycol etc. definitely makes cooling performance worse.
Water IS the best - period. We have also tried "nanotechnology" fluids with additives, no better results than water.
Recently we have begun to have our fluid made in the US and we are actually looking in to a fluid for karting/cars that will be water based but not with glycol but with anti bacteria/algae and corrosion protection. This fluid you will be able to flush and re use all you want, your stuff will look like new on the inside and it will not grease the track up if you spill it.
We will ship out some free samples when we are ready for people to try it out and see what they say but from a pure cooling perspective, there is absolutely no reason to look beyond water...
2012 Formula Car Challenge Vice Champion (Pro Formula Mazda)
2011 Rotax DD2 Masters National Points Champion
2011 NorCal DD2 Masters Vice Champion
2010 NorCal Rotax Masters Champion
www.viking-racing.com
http://www.facebook.com/VikingRacing
patrick slattery
PostPosted: Fri Dec 07, 2012 1:07 pm    Post subject: Reply with quote
Isn't water with a water weter better than straight water better at cooling?
Andre Eriksen
PostPosted: Fri Dec 07, 2012 1:20 pm    Post subject: Reply with quote
Perhaps in a drag racer or something like that. In a go kart no, in a computer liquid cooling system no. We have used a lot of it in the past for its anti corrosion properties.
PostPosted: Fri Dec 07, 2012 1:28 pm    Post subject: Reply with quote
Somebody is making a ton on snake oil!!!!!
Anybody need a bridge? Very Happy
CR
Russell Stevens
PostPosted: Fri Dec 07, 2012 1:30 pm    Post subject: Reply with quote
How about passing on some inexpensive radiators to the community... {puppy eyes}
Andre Eriksen
PostPosted: Fri Dec 07, 2012 1:34 pm    Post subject: Reply with quote
I will look at it next time I am in China. Problem is that I do not really have time/desire to start making mounts, selling, support etc. But I will ask next time I meet with one of our vendors out there. For Rotax it doesn't make sense as it would be illegal but that does not change the fact, that what they are selling for $400 would be less than $100 even with a big margin for Rotax, distribution as well as reselling.
Russell Stevens
PostPosted: Fri Dec 07, 2012 2:08 pm    Post subject: Reply with quote
The mounts are the easy part for the kart owner to make or come up with. Look at what we do already to make a chassis fit under a seat.
An inexpensive radiator with bolt tabs welded on, threaded inlet and outlet to allow the end user to attach whatever fitting they wanted, (and dare I say a curtain or shutters on the front). I mean really CRG how much does it cost you to make that stupid curtain. Thanks in advance for asking the supplier. Inexpensive parts that work are hard to come by in the motorsports industry.
Rusty
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.159526 (40.21%), total time:0.396733, queries:38
