Bondurant - LB
Brett King Design
SCCA Enterprises - FB
Anyone recognise this coil?
Steve O'Hara
PostPosted: Wed Dec 05, 2012 4:42 pm    Post subject: Anyone recognise this coil? Reply with quote
Got this in a pile of kart parts... anyone know what motor or ignition it works with?
Jim McMahon
PostPosted: Wed Dec 05, 2012 7:28 pm    Post subject: Reply with quote
When I googled the number on it, it came up a number of times in the TAGUSA local option rulebook:
http://tagracing.net/wp-content/uploads/2011/05/2011_TAG-Local-option_Tech_Manual.pdf
Looks like it comes on a lot of 100cc aircooled motors. Italsistem and parillas to start..
Steve O'Hara
PostPosted: Wed Dec 05, 2012 11:17 pm    Post subject: Reply with quote
Thanks Jim,
I did a search on the part number and came up with nothing.
Should have used Google.
Anyone know if the coil works with a Motoplat?
Steve
Roger Miller
Site Admin
PostPosted: Wed Dec 05, 2012 11:30 pm    Post subject: Reply with quote
This is out of the TaG manual:
Ignition system: Approved ignition systems are as follows: MotoPlat 9600-903-1 and 9600-916-1, Ducatti 436161191 and 436161190, PVL, and Selletra P3356. Serial numbers of rotor and stator for MotoPlat and Ducatti must match. Approved Ducatti coil 443213220090 only. Approved PVL ignition systems have potted or taped stators. Legal potted stators are numbered 1050, 1051, 1053, 1056, 1057, 1060, 1062, and 1063. Legal taped stators are numbered 01, 02, 04, 05, 06, 09, 10, 11, 12, 16 and 18.
Approved PVL coil 105.458 only.
It lists the coil number, and as a Ducati part which is how it is marked in your picture, and is shown as used with the Motoplats above, whether that covers what you need, I can't say, however, how many ways can you make a spark when you need it.
Steve O'Hara
PostPosted: Fri Dec 07, 2012 12:02 am    Post subject: Reply with quote
Roger,
Thanks for the additional info, looks like it is a kart coil and should work with the Motoplat systems that are still popular in vintage karting and dirt racing circles.
I'll hang on to it and see if anyone has a use for it.
Steve
DB time: 0.14515 (43.56%), total time:0.333188, queries:38
