OTK - LB
K1 Speed - SS
CRF 250 PROJECT
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
PostPosted: Tue Dec 04, 2012 12:37 pm    Post subject: Re: STARTING Reply with quote
paul rees wrote:
Chris Reinhardt <<< Chris I am glad your company can do these types of Mod's . But it would be nice if in the future, that you not use a photo of my engine and frame in your show in tell's . And claim as examples of your work. My Clutch cover was not Mod'd by your company . But it was done by Flat Track Engine Machine Shop Specialist. This cover type of work was done for me at a big discount. Because he was interested in my project. And no that is not a cut down socket in the photo ether. Paul
Sorry Paul, I never claimed that was my work, he asked how's done, so I showed him a picture..... I didn't have a picture of one mine handy....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
PostPosted: Tue Dec 04, 2012 4:27 pm    Post subject: Reply with quote
Well figuring out how to make this engine fit has been a challenge. My seat needs to be back a lot further than Howies so as the seat widens in front it's hard to clear the oil filter. This engine is considerably wider than a 2 stroke. Suprisingly it's only 13 lbs heavier than the Pavesi it's replacing.
I think I have it worked out pretty well and I'm surprised that off setting the seat more doesn't make it feel weird.
Now on to making the mount.
paul rees
PostPosted: Wed Dec 05, 2012 10:13 am    Post subject: Re: STARTING Reply with quote
CR
Thanks for reply
PostPosted: Thu Dec 06, 2012 7:02 pm    Post subject: Reply with quote
OK fuel pump set up. The round pump has 4 hose barbs. pulse, fuel in, fuel out and ?. On the pavesi the forth barb was the return to the tank but you guys are talking about putting in a Y in the out line and using that for return. What is the 4th barb for? Does that serve as a return? If not should it be plugged if a Y is used?
Howie Idelson
PostPosted: Thu Dec 06, 2012 11:57 pm    Post subject: Reply with quote
plug it and run the Y from the feed to the carb back to the tank.
Howie Idelson
howieidelson@mac.com
www.coroflot.com/howieidelson
PostPosted: Fri Dec 07, 2012 5:33 am    Post subject: Reply with quote
So I guess if the pump has 2 outlets the only purpose to using the Y instead of just returning the second outlet to the tank would be to get full flow closer to the carb before splitting for the return?
PostPosted: Sun Dec 09, 2012 2:23 pm    Post subject: Reply with quote
Well I'm up and running. I tried it in the neighborhood and it's a wild ride. Pretty cool not having to be in a narrow power band.
Now the coil and spark plug boot are incorporated so there is no coil wire. How did you guys get a Mychron to work. Where or how did you hook up the tach wire?
What's good operating temperature?
How is it on a bike they have no instrumentation? How would you know your not over revving or over heating??
PostPosted: Thu Dec 13, 2012 12:14 pm    Post subject: Reply with quote
WA LA CRF250 On the cheap!!! Runs Awesome!!!!
paul rees
PostPosted: Thu Dec 13, 2012 12:19 pm    Post subject: HONDA CRF250 Reply with quote
The thing it does need, is a chain guard. That's a lot of steel to have swinging around looking for some meat to munch on . Nice build though, one question though is that a twin muffler set up?
Benn Herr
PostPosted: Thu Dec 13, 2012 2:03 pm    Post subject: Reply with quote
The muffler looks like a Cherry Bomb! Cool
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
PostPosted: Thu Dec 13, 2012 2:08 pm    Post subject: Reply with quote
Yes the lower is a glass pack silencer with that alone it was still very loud. The upper is a 2" Thrush cherry bomb car muffler that quieted it down a lot. I have no idea how they effect performance they're both larger diameter than the OEM bike silencer and both straight through glass packs? And yes chain guard will be made just couldn't wait to give it a try.
PostPosted: Thu Dec 13, 2012 7:25 pm    Post subject: Reply with quote
I wouldn't worry about the back pressure so much, but you have a really, really, really long pipe on there!!!!
You could find yourself on OEM canister muffler off a sport bike before they starting going with the shorties and undertails. Most guys threw them away, try your local bike shop, most likely pretty cheap, $50 or less.
CR
Howie Idelson
PostPosted: Thu Dec 13, 2012 9:29 pm    Post subject: Reply with quote
I have an unused Pro Circuit titanium prototype muffler I will let go of. PM me if you're interested.
Howie Idelson
PostPosted: Fri Dec 14, 2012 12:00 pm    Post subject: Reply with quote
CR
If the back pressure is OK what is the concern about a long pipe?
paul rees
PostPosted: Fri Dec 14, 2012 12:07 pm    Post subject: Pipe Reply with quote
The length pipe does come in to play for tuning. A good after market Sportbike muffler will work great. I picked one at a swap meet for $5.00 it had two small scrapes from parking lot drop.
Page 3 of 7
DB time: 0.156425 (41.92%), total time:0.373188, queries:38
