SKUSA (non-flash) - LB
KG Plastics - FB
2013 Maxter, the straight up approach
Goto page 1, 2  Next
Keith Bridgeman
PostPosted: Thu Nov 29, 2012 7:37 pm    Post subject: 2013 Maxter, the straight up approach Reply with quote
Seems like the new approach is to get the cylinder as straight up and down as possible on the new ICC engines and they also seem more compact.
Merlin / Maxter KZ
Jim McMahon
PostPosted: Thu Nov 29, 2012 11:30 pm    Post subject: Reply with quote
Yeah looks like design is coming back to that setup, look at the angle on the inlet though. Street sweeper baby!
CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online
Tim Salvino
PostPosted: Fri Nov 30, 2012 6:29 am    Post subject: Reply with quote
So, i guess those angled motor mounts were useless... Rolling Eyes Laughing
Jim McMahon
PostPosted: Fri Nov 30, 2012 7:05 am    Post subject: Reply with quote
I think part of it is cost streamlining too. Bringing the KF and KZ motors closer together.
Paul Makarucha
PostPosted: Fri Nov 30, 2012 8:57 am    Post subject: Reply with quote
As I understand it, it is all being done for intake volume and velocity.
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Keith Bridgeman
PostPosted: Fri Nov 30, 2012 9:47 am    Post subject: Reply with quote
Nice to see an engine being updated Laughing just kidding. I want one. But after its built by someone, they would try to sell it to me for $9000.
Merlin / Maxter KZ
Charles Kaneb
PostPosted: Fri Nov 30, 2012 12:38 pm    Post subject: Reply with quote
The reed cages are still too small... look at a KTM or Honda GP125 engine and note that they put a far bigger cage in a tighter space.
The pipe draws on the crankcase when the engine's in the powerband, and the less restriction to inward flow the reeds give during this time the more air it'll move.
"If you're still in full control, you're not going fast enough" - Fred Frame
Bernard Muminovic
PostPosted: Fri Nov 30, 2012 12:51 pm    Post subject: Reply with quote
Keith...I almost had an orgasm when I saw this pic Twisted Evil
www.KartingConnect.com
www.neShifterKartSeries.com
www.facebook.com/neshifterkartseries
Jim McMahon
PostPosted: Fri Nov 30, 2012 1:05 pm    Post subject: Reply with quote
I think its a bit too easy to say the reed cages are too small. GP125 bikes are very different to a KZ. Different application and very different rules. The KZ motors have restrictions on exhaust port timing, have to use analogic igntion, fixed head vol of 11.5cc and suck on a 30mm carb. Besides, many of these these factories have had involvement from top GP two stroke tuners at some point, I think would give them a bit more credit.
Keith Bridgeman
PostPosted: Fri Nov 30, 2012 2:47 pm    Post subject: Reply with quote
Its known as the MXS
Merlin / Maxter KZ
Bernard Muminovic
PostPosted: Fri Nov 30, 2012 2:50 pm    Post subject: Reply with quote
List of things to buy for next season. (Check mark)
Bernard Muminovic
PostPosted: Fri Nov 30, 2012 3:28 pm    Post subject: Reply with quote
The main changes to the new engine are:
the cylinder has been made more upright
the angle of the reed block has been increased and moved closer to the cylinder
The result of these changes is the power hits faster and harder after shifting gear.
Jim McMahon
PostPosted: Tue Dec 04, 2012 2:17 pm    Post subject: Reply with quote
bah, jumped the gun...ignore..
mal crosher
PostPosted: Wed Dec 05, 2012 7:37 am    Post subject: Reply with quote
apart from rear exhuast they are starting to look like trials bike engines. I guess after having a successful formula together for a few years now they are going to start looking less and less like motorcycle engines they were based off. They have their control rules like carborator size ,ignition etc with everyone seemingly happy to toe the line.
Could probably move the gear selector tho. That will probably happen next ?????
One thing you always had to keep in mind with moto engines is not having the front wheel scrub the exhuast when full compressed always came first.
I was at pro circuit once back in 2002 and Mitch Payton was doing two team kx125 pipes for the teams 2 riders at an up coming supercross round. I asked why he was building them individually on each bike with forks collapsed. He said that both riders had different suspension settings, height and tyre profile etc and they tried to build the pipe as close to the wheel without scrubbing as possible. So in short, they could get way more out the engine with longer pipe than the port angles and /or bike geometry would allow. Was same at rear end with muffler too. Rear shock collapsed etc
Tom Barth
PostPosted: Fri Dec 07, 2012 6:18 pm    Post subject: Reply with quote
KZ10B is rotated rearward also. But not quite as much as MXS. But KZ10B as more of a straight in intake manifold. But both manufacturer's are putting carb as close to case as possible.
IMO there is not a 125cc engine on the face of the earth that will put out as much power as the current line of KZ engines assuming same specs. I've personally tried to get more out of the KZ with more compression, bigger carb etc. Just a waste of time and money. The 30mm carb, port angles and straight line ignition is matched perfectly to the KZ engine design.
The reason for rotating cylinder rearward is to move firing angle into a more favorable position - little more low end torque.
P.S. the older model KZ's will respond well to angled mounts and shorter intakes
Tom Barth
http://www.greenflagkarting.com/
Power is good...more power is better... too much power is just right!
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.147816 (39.99%), total time:0.369663, queries:38
