KartSport North America - LB
Streeter - SS
Franklin / Merlin USA - FB
To powder coat or paint...?
Goto page Previous  1, 2
Ted Hamilton
PostPosted: Fri Nov 30, 2012 6:02 pm    Post subject: Reply with quote
Just had my frame sandblasted at a local monument (funeral headstone) company. (Many aren't aware that they do such things, but mine was open to an "odd" project) Cost was $75.
I then took it to my local powdercoater who will do it for $75.
Last frame I took to an all-in-one shop an hour away and the total was $140. I just didn't feel like driving an hour this time...
$200 just for powdercoat seems a bit high just for the coating...
Owner, www.hamiltonhelmets.com // UAS Racer #76 // Karting for karting's sake...keep it fun!
Stanley Morgan
PostPosted: Fri Nov 30, 2012 6:09 pm    Post subject: Reply with quote
If you get it sand blasted, my wife took a course at the community college, and says she would be happy to paint it for free. She recommends "vintage tuscany brick entangled in vines and a tomatoes". What ever that means?
Stan
Don Guilbeault
Advertiser
Advertiser
PostPosted: Sun Dec 02, 2012 5:39 pm    Post subject: powder coat Reply with quote
Ken, I have heard DR Kart red will make it faster.
DRT Racing
don@drt-racing.com
www.drt-racing.com
DR Racing Kart
Authorized Rotax,
Mychron, Blendzall,
Hoosier Tires
MG tires
Fisher Racing Engines
Hegar Drive
Don Guilbeault
Advertiser
Advertiser
PostPosted: Sun Dec 02, 2012 5:41 pm    Post subject: powder coat Reply with quote
Ken, Then add a DRT/Brian Fisher power plant and your really fast!!
DRT Racing
don@drt-racing.com
www.drt-racing.com
DR Racing Kart
Authorized Rotax,
Mychron, Blendzall,
Hoosier Tires
MG tires
Hegar Drive
joseph hollinger
PostPosted: Mon Dec 03, 2012 10:22 am    Post subject: Reply with quote
Ken Schilling wrote:
Today I met with Dan Regan the owner of a very reputable powder coating shop in SoCal.
Primo Powder Coating (Huntington Beach)
www.primo-powder.com
He looked over my GP-9 frame closely and stated that the European frames are powder coated and that the Euro powders are significantly tougher and harder to remove than any powder coating available in the USA due to the Euro powders being less eco friendly than what's available in the USA (OSHA mandates them to be more eco friendly thus making them less tough). He took a key and showed me on my frame.
Ken,
I had my GP-8 powder coated a couple of years ago. Before I sent it in I used a utility knife to remove the paint. It's actually pretty easy to get most of it off and the paint that is left behind is easily removed by the blaster or dipper. Gives you a change to smooth out any grind marks too.
Ken Schilling
PostPosted: Mon Dec 03, 2012 10:28 am    Post subject: Reply with quote
I've done some additional calling around at SoCal powdercoaters and the lowest price I've found for just the powdercoating is $110 for a solid color and $180 for a candy color.
So, the total will run $190 - $260 (chem strip - $80).
Ken Schilling
SKUSA Data Administrator
Tim Doll
PostPosted: Mon Dec 03, 2012 7:29 pm    Post subject: Reply with quote
Definitely agree that powder coat is far more durable than any paint job.
However, I've had a chassis builder tell me that the elevated temperature needed to 'bake' a powder coat would mess with the heat treat of the chassis material. I was sceptical and checked with a materials expert at Boeing (one of the neat things about working at Boeing is you can find experts in many, many areas - most of which are more than happy to lend their expertise even if its not work related). His feedback was the ~400 deg F temp that they baked a powder coat at wouldn't affect the 1040 and similar alloys that are normally used for kart frames.
That being said - if they offered to 'bake' it at a lower temp than normal - I'd probably take them up on the offer, especially if there wasn't a significant cost impact.
Tim
Standard disclaimer - I'm FREE - No longer affiliated with any organization, I can say whatever I darn well please!.
Everett, Washington
Robert Brooks
PostPosted: Tue Dec 04, 2012 3:09 pm    Post subject: Reply with quote
I've had numerous frames dipped and powder coated, I've never noticed any impact to handling. Last time (2 yrs ago) the entire process cost me $125. Don't over think it....
Straightaways are for fast karts, corners are for fast drivers....
Chris Pacitto
PostPosted: Wed Dec 05, 2012 8:00 pm    Post subject: Reply with quote
I am an amateur powder coater (I do lots of small parts in my garage). A rough finish on the metal part (i.e., sandblasting) promotes adhesion of the powder to the metal.
Powder coating is a bitch to sandblast off. Chemical stripping is by far the easiest/fastest way to go. After thorough chemical stripping, a light to medium sand blast will remove any remaining powder in tight spots and texture the material.
Steel is normally heat treated at much higher temperatures and longer times than the 400f for 20 min required to cure (most) powder.
While you're at it, get your wheels powder coated to match Cool
Kerry Matthews
PostPosted: Mon Dec 10, 2012 3:27 pm    Post subject: Reply with quote
Went out to start pricing stripping/powdercoating here in NorCal for the 2 used frames I'm buying. No one up here does chemical stripping, (EPA sucks) and one shop told me to go to Home Depot and grab a can of JASCO paint remover. Media blasting only @ $80-$90 hr. I visited 4 shops, with another one I'll visit tomorrow. Stripping the chassis: $120-$150 each, which is where the JASCO might come in handy, removing a major portion of the time required to strip. Powdercoating: @$250 each, although one shop said if I brought them both chassis at the same time, same color, $175 each. Shocked In the words of Sammy Davis, Jr. "Ouch man, and I mean that!" Guess I better keep looking...
Play now, work later!
joseph hollinger
PostPosted: Mon Dec 10, 2012 3:30 pm    Post subject: Reply with quote
Mine cost me $350 and I had already stripped it.
Kerry Matthews
PostPosted: Mon Dec 10, 2012 5:04 pm    Post subject: Reply with quote
We have a winner!!!! Went to the last shop on my list, (and one that was recommended as being reasonable on price) and he quoted me $125 a frame. Now, with a little elbow grease, and maybe a little JASCO, (let's see how the utility knife works first) I can get the stripping fees down to $50 or less. THAT I can live with...
Jeff DeMello
PostPosted: Mon Dec 10, 2012 6:22 pm    Post subject: Reply with quote
You shouldn't wear your fancy suits and drive up in your new Mercedes, when you get a quote on a price Wink Laughing
Jeff DeMello
Emmick F125 Pavesi
joseph hollinger
PostPosted: Mon Dec 10, 2012 7:38 pm    Post subject: Reply with quote
Mercedes? My cars: Dodge, Mazda, VW.
Kerry Matthews
PostPosted: Mon Dec 10, 2012 8:31 pm    Post subject: Reply with quote
I came home to find a PM from my friend Dave, who works at a powdercoater. He wants to know if he's chopped liver... So I guess I CAN find a good price to get these done. Embarassed Cool Laughing
Page 2 of 2
DB time: 0.158043 (41.96%), total time:0.376642, queries:38
