Italian Motors - LB
K1 Speed - SS
OTK 30 vs 32 mm
Jason Vehige
PostPosted: Wed Nov 28, 2012 1:24 pm    Post subject: OTK 30 vs 32 mm Reply with quote
Looking for thoughts on which way to go... 30 or 32 mm for low grip, bumpy, temporary circuits... High HP (KZ)... Driver is 6'4" 230 pounds.
Conventional wisdom = 32mm but I hear rumors of some big guys having good luck with 30mm stuff from OTK
Anyone know the weight difference between the 2???
Jason Vehige
05 Vanspeed Sirio / SGM sl204
gregg boyce
PostPosted: Sat Dec 01, 2012 7:54 pm    Post subject: Reply with quote
With a driver that size AND a KZ go with the 32mm. I've driven both (5'11" 180lbs). I think with your height and weight the 30 would flex too much. You will probably need to run less caster than others to keep the rear from lifting too quickly/too much.
GB
PostPosted: Sat Dec 01, 2012 8:55 pm    Post subject: Reply with quote
32mm. You'll struggle to stiffen the 30 up enough to handle the weight/power.
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
DB time: 0.141901 (44.06%), total time:0.322069, queries:38
