OTK - LB
A little Advice On Set Up
Tyson Henry
PostPosted: Wed Nov 28, 2012 7:30 am    Post subject: Reply with quote
Brian Degulis wrote:
The front hubs are already all the way in. So I'm left with loosening the bearing or adding castor. I also noticed my rear hubs are very long I wonder if shorter hubs would help it flex?
You want to remove caster, not add.
PostPosted: Wed Nov 28, 2012 10:24 am    Post subject: Reply with quote
OK I'm confused. To remove castor would the top of the spindle need to go toward the front of the kart or the rear? It would seem to me in order to add lift the top of the spindle would have to be moved toward the rear?
I can't find any ID on the axle but it does apear thicker in comparision to othe 40 MM axles I've seen. I would think a measurment of wall thickness should would ID it.
Michael Taksa
PostPosted: Wed Nov 28, 2012 10:26 am    Post subject: Reply with quote
Top forward to remove caster, decrease the angle. To fix the hop you need to decrease the lift, not the other way around, hop is cause by too much lift of the inside tire. And remember, in most cases changing caster chenges toe and camber.
PostPosted: Wed Nov 28, 2012 10:35 am    Post subject: Reply with quote
Ok removing caster creates less lift I understand that but how would reducing lift cure a hop? I was under the impression the hop was because it wasn't breaking free enough in other words breaking and grabbing.
Michael Taksa
PostPosted: Wed Nov 28, 2012 10:37 am    Post subject: Reply with quote
Not enough lift equals a slide, just enough lift equals perfect line through the corner, too much lift causes the "breaking free" and then grabbing and starting the whole process all over again.
Dan Haynes
PostPosted: Wed Nov 28, 2012 10:54 am    Post subject: Reply with quote
Here is a little analogy I heard before...sorry to whoever I stole this from. Take a pencil eraser and lay it down almost flat. It will slide pretty easily. The more you stand it straight up and down the more resistance you get. At a certain point it will start to 'hop'. Each subsequent hop creates an even bigger hop.
It sounds like you need less lift. A harder axle might help but try the front end settings first.
Blaise Haynes
#3 Arrow X1-CIK
TaG
Matt Dixon
PostPosted: Wed Nov 28, 2012 9:54 pm    Post subject: Reply with quote
After front end changes if it still happens, borrow some large rear hubs. It they improve the handling then change to a harder axle and go back to the smaller hubs.
Matt Dixon
94y Energy Corse/Swedetech
PostPosted: Thu Nov 29, 2012 5:22 am    Post subject: Reply with quote
OK I understand and will try removing caster. If to much grip is the problem then why would removing the rear torsion bar improve eliminate some of the hop?
Michael Pagano
PostPosted: Thu Nov 29, 2012 3:27 pm    Post subject: Reply with quote
Almost never run a rear torsion bar. it adds lot of grip. which makes it hop. maybe use it in the rain in some situations.
PostPosted: Thu Nov 29, 2012 6:08 pm    Post subject: Reply with quote
So the torsion bar stiffens the chassis and adds grip. Now it's all making sense. You guys are giving me an education THANKS!!!!
Barry Hastings
PostPosted: Tue Dec 11, 2012 9:14 pm    Post subject: Reply with quote
is the kart "hopping" or kinda "flopping" I once had this same issue that i couldn't adjust out. One day i broke down in one of the corners i was having a problem with and i got to watch the other guys on the track. What i learned from that observation was the guys who didnt have the "hop" and another that was. It was that the "hop" was actually a "flop" and the guy who had it was coasting and the kart just wasn't happy, the guy who didn't have problems was on the gas. not a lot just enough to keep the kart from "flopping". Next time i drove, i worked with trailing on the gas and THAT particular problem went away.
Something to try.
PostPosted: Mon Jan 07, 2013 4:31 pm    Post subject: Reply with quote
Well adjusting the castor and shorter rear hubs solved the problem in fact it made a huge diffrence everywhere on the track. I'm working on another kart now with a similiar problem hopefully the same solutions will work. I'm now understanding that HP is only part of the equation and how important handling realy is.
Thanks for your help guys!!!!!
Ken Schilling
PostPosted: Mon Jan 07, 2013 4:42 pm    Post subject: Reply with quote
... I'm now understanding that HP is only part of the equation and how important handling really is.Brian
Brian, by understanding this you have a leg up on many other karters who feel that HP is the only answer.
Just remember this, the lower the HP the more important handling is.
Ken Schilling
SKUSA Data Administrator
Michael Taksa
PostPosted: Mon Jan 07, 2013 5:24 pm    Post subject: Reply with quote
Nah!!!!! You guys have it wrong, if someone passes you they have better motor:)
PostPosted: Mon Jan 07, 2013 6:58 pm    Post subject: Reply with quote
I still have a lot to learn but it surprised me how much faster I got with a well balanced chassis and how much less fatique there is when you get the momentum and flow going.
Page 2 of 3
DB time: 0.149128 (42.01%), total time:0.354971, queries:38
