RLV - SS
SCCA Enterprises - FB
Real Gas
PostPosted: Fri Nov 23, 2012 8:55 am    Post subject: Real Gas Reply with quote
Don't have a real gas station around here. Is there a way to evaporate ethanol out of pump gas?
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Ted Hamilton
PostPosted: Fri Nov 23, 2012 9:12 am    Post subject: Reply with quote
YMMV...
http://www.ehow.com/how_7830109_remove-ethanol-gasoline.html
But I've heard that phase separation causes some other issues:
http://www.fuel-testers.com/expiration_of_ethanol_gas.html
Could do a phase separation, then run the resulting gas through a chamois for the final water straining... Be advised octane number will drop, however... Smile
Owner, www.hamiltonhelmets.com // UAS Racer #76 // Karting for karting's sake...keep it fun!
Mark J. Schoonover
PostPosted: Fri Nov 23, 2012 9:54 am    Post subject: Reply with quote
Try this website;
http://pure-gas.org/
Dan Rudd
PostPosted: Fri Nov 23, 2012 4:39 pm    Post subject: Reply with quote
I was told once that marinas still sell fuel without all the ethanol. I've never looked into it though.
Dan
Ted Hamilton
PostPosted: Fri Nov 23, 2012 5:51 pm    Post subject: Reply with quote
Oh, and forgot to menton, stop at your local municipal airport -- they'll have 100LL, probably. Mine does, and pretty cheap.
PostPosted: Fri Nov 23, 2012 6:07 pm    Post subject: Reply with quote
Dan
Yes most (not all) marine pumps are non ethanol. You could also go to a local cycle shop that deals in dirt bikes and get pre packaged 5 gal race fuels. A little pricey but not outrageous. Also most tracks Kart or auto have fuel.
Stay away from ethanol it's nothing but trouble.
PostPosted: Fri Nov 30, 2012 5:44 am    Post subject: Re: Real Gas Reply with quote
Gif Cool
Gif, with an FAA license what not just buy 100LL?
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Mark J. Schoonover
PostPosted: Fri Nov 30, 2012 7:43 am    Post subject: Reply with quote
Racing Gasoline vs Aviation Gasoline;
http://www.rockettbrand.com/techsupport/documents/TechBulletins/RacingGasolineVsAviationGas.pdf
Jim McMahon
PostPosted: Fri Nov 30, 2012 9:13 am    Post subject: Reply with quote
KT100 is used in aircraft isnt it Smile
and Aixro Smile
PostPosted: Fri Nov 30, 2012 11:17 am    Post subject: Reply with quote
I'm kinda leery of a race fuel distributor talking about how bad avgas is....
Also realize that's about all they run in karts and bike in Europe, and understand that avgas in 2 stroke, actually helps suppress detonation...
As compared to low octane, unleaded, 10% alky pump gas, I'll take avgas any day...
If you're talking oxygenated race fuels, now that's a different story...
CR
Dean Graves
PostPosted: Sun Dec 02, 2012 9:02 am    Post subject: Reply with quote
Walt, just go to a motorcycle shop and spend some cash.
PostPosted: Sun Dec 02, 2012 9:33 am    Post subject: Reply with quote
I'm just trying to put my mower away for the winter.
PostPosted: Sun Dec 02, 2012 2:30 pm    Post subject: Reply with quote
Well, why didn't you say so!!!!
Power Mist in northern Jersey used to make some stuff called Tool Fuel. It was developed when someone died because a fireman's demo saw I believe it was, wouldn't start because the fuel was stale..... I guess it's like adding Stabil to the fuel, except if this is the only fuel you use, it will always be protected from going stale.
CR
DB time: 0.070485 (19.6%), total time:0.359539, queries:38
