OTK - LB
RLV - SS
Franklin / Merlin USA - FB
Kelgate brake fluid
Gerry MacNutt
PostPosted: Wed Nov 21, 2012 11:11 am    Post subject: Kelgate brake fluid Reply with quote
So it's time for new brake fluid my understanding is Kelgate brakes want silicone Dot 5 fluid, if that is correct what would be the best brand?
Second from the Wilwood site: " Wilwood does not recommend using DOT 5 fluid in any racing applications".
Sam Moss
PostPosted: Wed Nov 21, 2012 11:32 am    Post subject: Reply with quote
I use normal DOT 5 fluid in my Kelgate brakes. Kelgate do their own silicone fluid that is purple colour but I've found no difference between that and the racing DOT 5 fluid. DOT 5 also has a higher boiling point than DOT 4.
I think its Millers we use.. Been running it for over 6 years now with no problems. Replacing every 5/6 meetings of course.
Tim Doll
PostPosted: Wed Nov 21, 2012 12:01 pm    Post subject: Reply with quote
There is considerable debate regarding DOT 4 Glycol and DOT 5 Silicon fluid for racing applications. But the most critical aspect is, YOU CAN'T MIX THEM.
If it's got Silicon fluid in there now, you can't switch to Glycol unless you do a complete system rebuild and replace all the seals (making sure the seals are compatible with the fluid you are going to use). If you're unsure what's currently in there, remove a couple drops of fluid and add them to a spoonfull of water. If it readily mixes - it's Glycol based. If it stays separate (think oil and water), it's Silicon.
Tim
Standard disclaimer - I'm FREE - No longer affiliated with any organization, I can say whatever I darn well please!.
Everett, Washington
PostPosted: Wed Nov 21, 2012 12:13 pm    Post subject: Reply with quote
Silicone doesn't have the lubricity that Glycol based does, and the new DOT4 fluids boil as high or some even higher than DOT5's.
But seal compatibility is the main reason to stay with whatever the manufacturer suggests.... All the Brembo stuff we run use DOT4, I use Castrol LMA fluid, boils at 500+.
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Greg Cavouras
PostPosted: Wed Nov 21, 2012 2:12 pm    Post subject: Reply with quote
I have had good luck with Bel Ray dot 5 fluid in my Kelgate system. Works well and widely available.
Gerry MacNutt
PostPosted: Wed Nov 21, 2012 7:55 pm    Post subject: Reply with quote
Thanks, for the replies, I've never used dot 5 before so I'll have to test it and see if it is indeed dot 5
are all the seal available to covert to dot 4 for kelgate brakes?
Matthew Walker
PostPosted: Wed Nov 21, 2012 8:16 pm    Post subject: Reply with quote
Spectro do a good Dot 5 Silicon fluid - most Harley's use Silicon as it doesn't harm the paint like traditional fluid does Smile
Experience is that marvelous thing that lets you recognise a mistake when you make it again!
Jeff Salak
PostPosted: Wed Nov 21, 2012 11:31 pm    Post subject: Reply with quote
Some Kelgate Dot 5 brake fluid for sale on ebay. Here is the link.
http://www.ebay.com/itm/Kelgate-OTK-Tony-Kart-DOT-5-Silicone-Brake-Fluid-2-pcs-24-oz-Total-/280953321816?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D3633542990662713864%26pid%3D100015%26prg%3D1006%26rk%3D2%26sd%3D160701407875%26
John Michael Dillon
PostPosted: Thu Nov 29, 2012 7:51 pm    Post subject: Reply with quote
I've used DOT 5 in my shifter karts for years. I use it in the 250 with Kelgates. The main reason I like dot 5 over 4 is with the style of brakes used on most karts, including 250's there are no dust seals on the calipers to keep moisture out, like when in the rain. Dot 4 absorbs that moisture much quicker. Also helps keep the aluminum calipers from corriding. Just my opinion
PostPosted: Thu Nov 29, 2012 9:43 pm    Post subject: Reply with quote
Just a couple of observations..... If your getting water from the track through the seals in your calipers, you have bigger problems!!! There may not be a dust seat (which is to keep out dust on the pistons) but there's an oil seal around the caliper piston that keeps the brake fluid in, and damn well better keep water out!!!!
The thing to remember about silicone fluid and water, as been stated, it doesn't mix which means if you get water in DOT5 brake fluid, water by itself with contact the parts, and the fact the oil is lighter, the water will sit on the bottom. It's actually worse at protecting your brake system from corrosion than DOT4.
Do a search, besides the fact that some DOT5 has higher boiling points than some DOT4, there really isn't anything better about it...
CR
John Michael Dillon
PostPosted: Sat Dec 01, 2012 8:15 am    Post subject: Reply with quote
Very good points Chris. Thank you. I guess I've been miss lead all these years by Kart manufactures. I know in the automotive world dot 5 is a no no. I should have taken that reasoning and applied it to the kart world. Next time I go through my brakes I think I'll change.
PostPosted: Sat Dec 01, 2012 9:50 am    Post subject: Reply with quote
It's funny, I went through all this when I was putting the whole Cobalt kart together. I looked at the Brembo calipers, which were DOT4, and the MCP masters which could be either. I took a closer look at everything, and I thought just like you, DOT5 is for racing, it's the stuff! I even have 6 bottles of Maxima DOT5 left over from my Anderson. The more I looked into it, the less positive things I read about DOT5.
If the system is compatible with DOT4, a good DOT4 is the way to go in my opinion.
But be careful, if they are not EP seals, the system may not be compatible with a DOT4, and when switching, you need replace all the seals and completely flush the whole system.
Good luck....
CR
DB time: 0.235895 (47.9%), total time:0.492431, queries:38
