IKF Region 7 - LB
Brett King Design
Leading Edge Motorsports
United States Pro Kart Series
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 16, 17, 18  Next
Kyle Prokup
PostPosted: Fri Nov 30, 2012 6:30 pm    Post subject: Reply with quote
Michael Tancredi wrote:
I would be interested if they got rid of the Can exhaust for the Yamaha.
For anyone that will actually run Yamaha in this series: what is your opinion on keeping the can? I have yet to test the new pipe myself (tomorrow I will chime in) but I really believe its a formula that will work. The pipe appears to be relatively similar to what is used in Australia, and from what I hear the Yamaha is far from failing there.
I may have missed this detail as information is all over right now, but I think its important to not have a purse in the Non-Pro Leopard division. I think that would make a better, more clear seperation between the drivers and their budgets between the two classes. Maybe a set of tires to the top 3 as thats an inherent regular cost to any driver competing at this level.
As for people saying the engines aren't Euro enough, I think the comment about similar "Pro" series is spot on. Those series haven't worked well in the US because there isn't enough direct factory support to create a high profile event; anything WSK level. Kart shops supporting series' here in the US makes our abilities much different. The Yamaha has lasted a long time for a reason, but I think aspects of the package could be updated from what has been learned.
Take what America does right, and put it on a big scale. I like it.
Kyle Prokup Racing
Tony Kart EVRR
Tim Koyen
Advertiser
Advertiser
PostPosted: Fri Nov 30, 2012 7:16 pm    Post subject: Reply with quote
Lots of good info and ideas here.
www.kartlift.com
www.facebook.com/kartlift
Nathan Adair
PostPosted: Fri Nov 30, 2012 7:52 pm    Post subject: Reply with quote
Not much talk about it yet, but I really like the idea of the Leopard Semi-Pro class. As a 25-year-old skinny newb, 14+ and 330lbs really appeals to me, and the header makes sense since the weight is low. It's hard to get into karting at my age with TaG Senior being about my only option in Florida, and it's the deep end of the pool. Yamaha Senior doesn't seem too popular at the regional level and I'm not old enough or fat enough for Masters or Heavy.
With that said, I can't help but think that Semi-Pro is intended more for the experienced TaG Jr. drivers that are waiting to turn 16. I hope I'm wrong.
Ray Mcik
PostPosted: Fri Nov 30, 2012 9:46 pm    Post subject: Reply with quote
Gary Osterholt wrote:
Talking about Masters. I wish series would make an age.
SKUSA is 30+
Rotax is 32+ or weight
WKA is 35+
USPKS is 35+
good point Gary,
look despite what many think that beer is the main cause of the dreaded beer gut and added weight
Metabolism slows down after the age of 35, so you may find that the more calendars you go through, the more trouble you have keeping a trim figure.
So I think 35 is good age for Masters level classes... for me, it was my 40's when I started slowing down a "bit'
Wink
Ohio Valley Karting Association
WWW.OVKA.COM
Tim Koyen
Advertiser
Advertiser
PostPosted: Fri Nov 30, 2012 10:29 pm    Post subject: Reply with quote
Actually, I think it will be for both. Inexperienced Junior drivers getting ready to join the Pro ranks, and new Senior drivers who aren't quite ready to jump into the deep water yet. There is probably a little room to tinker with the weight for this class yet to make room for the "rookie" senior drivers, but it should be a good starting point for someone wanting to take the next step from Tag club racing. Juniors wanting to gain some practical Tag experience will also benefit from a little time in this class.
www.kartlift.com
Dan Schlosser
PostPosted: Fri Nov 30, 2012 10:56 pm    Post subject: Reply with quote
We talked about it and I think our opinion (Andy & I - not anyone else that runs with us) is that we probably won't run the Can regardless but if it was Pipe we'd probably try it for at least a race. Looks like a fun combo.
Tony Granata
PostPosted: Sat Dec 01, 2012 4:39 am    Post subject: Reply with quote
Kent's data shows (hands down) the pipe is the way to go. Any Yam Jr moving up (as my kid is) wants to see the pipe not the can. Any cross over racers don't want to change back.
GO WITH THE PIPE FOR YAM SR!
If not, Coats, Koyen and Laukiatis will be getting a visit from a couple of "lil Italy's" uncles! Shocked [/url]
Frankie Schaffier
PostPosted: Sat Dec 01, 2012 8:01 am    Post subject: Reply with quote
I agree.. I think the pipe would be a good move in the long run.
And not just because I bought one, but I feel it's a step forward for the Yamaha class from where it's at today. Locally I hear quite a bit of complaining about the soup can exhaust, but then again they were not dancing in the street when the pipe costs where known. But buying a pipe isn't something that faded away years ago, the KPV teams do it now, along iwth other classes. I personally feel the cost of the pipe and header is reasonable, call it a set tires cost wise, but you don't throw it away at the end of the day.
I know everyone hates having two weights for one class, but if entries are a concern throw 15 pounds at the pipe. Should be able to use Daytona numbers to compare pipe times vs can and come up with a weight. It's pretty clear at the scales what is what, even for someone's daughter who drew the short straw and has to write down weights.
I haven't driven the pipe set up yet, but I've yet to hear anyone who has not said it's better then the can.
Tires... Instead of a spec tire call out tires from all manufactures that can be used and don't allow the gumballs. Burris, Stone, MG, Dunlop or whatever, guys will already have them in their trailer. Open it up to whoever the karter wants to buy from. It's just weird to me when talking to guys at the track, reading on forums like this where guys are trying to get their kart loosened up, get rid of the hop, get rid of the bind, ect. Bigger axles, bigger frame tubes, bigger spindles, more seat struts which equals more cost, chasing sticky tires. But yet the orgs keep spec'n sticky tires?
Just my thought's.. Either way I'll run the series and I haven't done that in awhile, it's a welcome change and sounds like fun.
Frankie
Comet Eagle
Emmick Elite-Parilla TT25
Burris Racing www.burrisracing.com
Stoney Creek Motorsports
patrick slattery
PostPosted: Sat Dec 01, 2012 9:31 am    Post subject: Reply with quote
Pipe is going to be a big hit, more bottom end power and much more quite, and no need for a 3 disk wet clutch. Your standard dry can clutch should be all that you need.
Brian McHattie
PostPosted: Sat Dec 01, 2012 11:34 am    Post subject: Reply with quote
The only classes nationally that allow what you refer to as "gumballs" are Tag on the east coast, and Tag and Shifters on the west coast. The B-Stones everyone runs in the yamaha and KPV classes are a CIK-H (Hard) tire compound, the TaG's in other series use either a series specific tire (basically a medium compound) or the CIK-M (medium) compound tires. Mediums are B-Stone B's, Dunlop DEM, MG Yellow.
Brian McHattie
www.dbmotorsportsonline.com
all your graphic needs
Frankie Schaffier
PostPosted: Sat Dec 01, 2012 12:21 pm    Post subject: Reply with quote
Brian,
I clearly understand the componds and am also aware what is currently being ran as the natioanl tires. The point I was making is that the tires are driving the $4000+ chassis and it dosen't have to be that way. For me personally, it don't matter. I'm blessed to be able to afford three sets of tires for a week-end no matter what kind or the cost of a set. My focus is on the local guy that wants to run a series and can't afford to go buy a new $4000 chassis along with 3 sets of tires for an event. The guy that wants to run a series with him and his son both driving, on 4 year old karts and be able to afford to do that.
The folks that are running this series understand for this to be sucessful something needs to be done to cut the costs. They understand that things need to change away from what is happening today with the different series across the nation. For the Yam classes in this series only one set of tires is going to be allowed for both Sat and Sun racing. Awesome decision! Run a used set for Friday practice, mount a fresh set for the rest of the week end. It's about damn time..
What I was suggesting was to not limit the tire brands to just one tire company. Allow guys to run what they want, just cap the how soft a tire that can be ran. I don't get free tires only free decals, so givin a choice, I'd rather pay $165 for a set then I would $215. a set. If I get beat because of my tire pick, well then so be it. I was able to decide how I'm going to spend my money and I feel everyone should have that ability.
The sport can not survive off high dollar guys, there's not enough of them.
Please don't think I'm taking a shot at you Brian, that's not the case. Again, just offering my opinion as messed up as it may be.
Frankie
Comet Eagle
Jim McMahon
PostPosted: Sat Dec 01, 2012 2:26 pm    Post subject: Reply with quote
Ive always liked the idea of allowing a selection of tires in a certain durometer range rather than spec'ing a brand. Bridgestone, Hoosier, Vega, MG, Dunlop, Burris whatever. Run what you brung, as long as its mass produced and meets the durometer range specified. Easy way to do it would be to say CIK-H (for example) only, but then you push out Hoosier and Burris which is just plain wrong. I think a little pricing competition with tires wouldn't do any harm and I think it's an absolute disgrace that there isnt more support across tracks and orgs for Hoosier and Burris for all the flag waving that goes on sometimes.
Kyle Prokup
PostPosted: Sat Dec 01, 2012 5:37 pm    Post subject: Reply with quote
I like the idea of open tires, but I'd hate to see a series be known for drivers having racks of tires in every trailer; it would look like a dirt race. And adding restrictions would only create controversy.
Tested the pipe today: I'm for it. Pulls off the corners nicely and sits on the straights like a supercan: ie still going to have pack racing. I also think it'll keep clutch wear lower, as the motor has more power to get off the clutch stall faster so it doesn't struggle to engage as long.
Kyle Prokup Racing
Tony Kart EVRR
Jim McMahon
PostPosted: Sat Dec 01, 2012 6:23 pm    Post subject: Reply with quote
I'm not sure if it would become an epidemic like in dirt racing though. You'll always get people that have the means to go nuts testing that kind of stuff but I'm not sure if will really make all that much of a difference if you stick with a harder, more durable compound/durometer range.
Jeff Stamper
PostPosted: Sat Dec 01, 2012 8:39 pm    Post subject: Reply with quote
Is there a website for the series or did I just miss it ? Thanks
Racing is a State of Mind ! ... A very nice state to be in !
Page 8 of 18
DB time: 0.263831 (32.16%), total time:0.820346, queries:38
