Bondurant - LB
Top Kart USA - SS
KG Plastics - FB
How to check the crank on CR125, How much play?
Goto page Previous  1, 2
Gerry MacNutt
PostPosted: Thu Nov 22, 2012 3:07 pm    Post subject: Reply with quote
The middle of the bridge expands when hot, hence when cold if you could look at it from the side it should look slightly banana shaped, so if you put a steel straight ruler on it vertically you would see a slight gap of air in the middle that transitions back to normal on top and bottom as it gets to the main area of the barrel. The idea is while is is at operation running temp it expands to a straight line, hence this then does not push the ring into the back of the gap on the piston. A little 400 and 600 wet with WD-40 will do the trick, the art of it is to take off just the right amount and transition shape. That comes with many years of motor build to know just the right combo. Don't destroy the plating. Practice on a junk barrel.
Tyson Henry
PostPosted: Thu Nov 22, 2012 4:17 pm    Post subject: Reply with quote
Wouldn't this also be illegal?
valentin yakimenko
PostPosted: Thu Nov 22, 2012 4:22 pm    Post subject: Reply with quote
Lol... What are you allowed to do.to the engine then..lol. if nothing then how all the engine builders make living...ha ha ha
Toys: 2000 CRG storm powered by cr 125 Stock Moto.2007 F 350 powerstroke. 2012 Yamaha Raider 113ci
Gerry MacNutt
PostPosted: Thu Nov 22, 2012 7:46 pm    Post subject: Reply with quote
I don't run this class, the question to me did not concern a rules issue.
Michael Taksa
PostPosted: Fri Nov 23, 2012 6:38 am    Post subject: Reply with quote
Valentin, in "Stock Honda" class you are really required to keep pretty much everything OEM-Stock. In Mod Moto class you can experiment with cylinders, ports, pistons, heads, etc.
Vernon Head
PostPosted: Fri Nov 23, 2012 11:12 am    Post subject: Reply with quote
The cylinders that I have bought already had a relieved exhaust port from the factory.
valentin yakimenko
PostPosted: Fri Nov 23, 2012 11:38 am    Post subject: Reply with quote
Are you running 99 or 01 cylinders?
Vernon Head
PostPosted: Fri Nov 23, 2012 11:41 am    Post subject: Reply with quote
99.
valentin yakimenko
PostPosted: Fri Nov 23, 2012 11:44 am    Post subject: Reply with quote
You got yours from Honda dealer or kart parts destributor?
Vernon Head
PostPosted: Fri Nov 23, 2012 12:02 pm    Post subject: Reply with quote
Service Honda.
Page 2 of 2
DB time: 0.157722 (45.05%), total time:0.350108, queries:38
