2D2W - LB
Top Kart USA - SS
KG Plastics - FB
How to check the crank on CR125, How much play?
Goto page 1, 2  Next
Michael Taksa
PostPosted: Mon Nov 19, 2012 7:58 am    Post subject: How to check the crank on CR125, How much play? Reply with quote
Doing top end on stock CR125 and would like to check the crank bearing play. How much up/down or side/side play is OK? Do you check by grabbing the rod and moving by hand?
Thank You.
Greg Lindahl
PostPosted: Mon Nov 19, 2012 10:48 am    Post subject: Reply with quote
You "rock" the small end from side to side while the large end is in the middle of its bearing and measure the length the small end moves. Check the measured length against the tolerance specified in the Honda CR 125 manual.
If you don't have a manual, get one, it's a great investment in engine longevity and "economical" race engine maintenance.
Michael Taksa
PostPosted: Mon Nov 19, 2012 4:55 pm    Post subject: Reply with quote
The cut window on piston and "IN" is facing the carb, correct?
valentin yakimenko
PostPosted: Tue Nov 20, 2012 7:12 am    Post subject: Reply with quote
Yes, the the side with window cut in piston faces carb. Make sure you drill the exhaust side if it doesn't have holes already.
Toys: 2000 CRG storm powered by cr 125 Stock Moto.2007 F 350 powerstroke. 2012 Yamaha Raider 113ci
Michael Taksa
PostPosted: Tue Nov 20, 2012 8:25 am    Post subject: Reply with quote
Can't touch it, "Stock Honda", no mods of any kind.
valentin yakimenko
PostPosted: Tue Nov 20, 2012 9:01 am    Post subject: Reply with quote
I belive that is allowed. Let's see.what others gotta say. Im talking bout drilling two holes on piston's exhaust side for lubrication. It will not make you faster, but will prolong the life of piston and cylinder!
valentin yakimenko
PostPosted: Tue Nov 20, 2012 9:03 am    Post subject: Reply with quote
Here's more info on how to do this. http://metal-matrix.com/s/index6.html
Michael Taksa
PostPosted: Tue Nov 20, 2012 10:03 am    Post subject: Reply with quote
So will the oringed head gasket, but that is not allowed either.
valentin yakimenko
PostPosted: Tue Nov 20, 2012 10:10 am    Post subject: Reply with quote
I don't have anything to proove, just trying to help. I will run that, till I'm told not to by officials..
John Motley
PostPosted: Tue Nov 20, 2012 11:11 am    Post subject: Exhaust side piston holes Reply with quote
Consider yourself "told', if you run SKUSA events.
John Motley
National Technical Director
SKUSA
valentin yakimenko
PostPosted: Tue Nov 20, 2012 11:27 am    Post subject: Reply with quote
All we got is wka...here
Noah Stark
PostPosted: Wed Nov 21, 2012 1:34 pm    Post subject: Reply with quote
And if you run WKA roadrace series Stock Honda class, also consider yourself told. You will be DQ'd on the spot for drilling those holes. It is not allowed.
Noah Stark
RIP my friend:Paul Dana you will be missed by many
valentin yakimenko
PostPosted: Wed Nov 21, 2012 1:41 pm    Post subject: Reply with quote
Lol...damn...thanks guys....wonder why is it illigal to prolong the topends life...but thanx anyways...
Gerry MacNutt
PostPosted: Wed Nov 21, 2012 8:39 pm    Post subject: Reply with quote
While you won't be able to measure it on a dyno it would actually cost you a bit of power as it bleeds around the bridge and in turn drops drops crank case pumping slightly. Releive the bridge in the proper fashion and you will have no need for the holes. Bridge holes are for forged pistons.
valentin yakimenko
PostPosted: Thu Nov 22, 2012 3:23 am    Post subject: Reply with quote
Sorry, I'm new here, what's the propped fashion to relieve the bridge?
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.143756 (41.63%), total time:0.345341, queries:38
