SKUSA (non-flash) - LB
Plumbing a Mikuni Fuel Pump
Evan York
PostPosted: Sat Nov 17, 2012 6:34 pm    Post subject: Plumbing a Mikuni Fuel Pump Reply with quote
I have a stock-moto CR125 with a PJ carb (it's a 1995 motor), and I have read several different ways to plumb a fuel pump.
What is the best method of plumbing a round Mikuni fuel pump?
Thanks![/img]
Regards,
Evan York
www.evan-york.com
@EvanYork
"That which you manifest is before you" - Enzo the dog
Vernon Head
PostPosted: Sat Nov 17, 2012 7:52 pm    Post subject: Reply with quote
I'll start. I have a Mikuni TMX38. The best thing so far for me is to run one line straight back to the tank as a return line (use the outlet straight across from the intake). The other outlet goes to the carb. That's it.
Michael Taksa
PostPosted: Mon Nov 19, 2012 7:51 am    Post subject: Reply with quote
Same thing works for me with Mikuni TMX, round pump. pulse line, line from tank, line to carb, line back to the tank from the pump itself. The return line is pointed somewhat "up".
valentin yakimenko
PostPosted: Mon Nov 19, 2012 12:52 pm    Post subject: Reply with quote
Evan, you shoulda took a pick of the way I routed it... Never had problems, even on long straights...
Toys: 2000 CRG storm powered by cr 125 Stock Moto.2007 F 350 powerstroke. 2012 Yamaha Raider 113ci
Jason Berry
Advertiser
Advertiser
PostPosted: Fri Nov 30, 2012 9:48 am    Post subject: Fuel Pump Connection Reply with quote
This might help
http://www.swedetechracing.com/news-events-blog/swedetech-technical-help/how-to-connect-a-single-fuel-pump-to-a-keihin-carburetor-for-karting-use/
If you are using the round mikuni pump, for the line going to the carburetor, use the nipple that is 180 degrees from the inlet nipple. Block of the the other nipple that is not in a straight line with the inlet nipple.
www.shopswedetech.com
www.facebook.com/Swedetech
DB time: 0.097506999999998 (34.45%), total time:0.283009, queries:38
