Acceleration - LB
MRP - SS
comer 50 clutch shoe moving?
marc-andre hubert
PostPosted: Thu Nov 15, 2012 7:01 pm    Post subject: comer 50 clutch shoe moving? Reply with quote
been getting noise in the clutch cover area, even some good grabbing (spinning wheels and it grabs to stop wheel from turning), shoe were new but no the springs, anyway receive BP clutch with spring today, at first its fine, then after some revs, you hear it.
remove cover and 2 shoes are slightly pulling away from crank and rubbing a bit into cover was not doing that before?
Ron Gordon
PostPosted: Thu Nov 15, 2012 8:04 pm    Post subject: Reply with quote
I had the same problem before...
You may have a slightly bent crank....
Would also bet the case bearings are in need of replacement as well.
Ron
Just another one of the Many OVKA Karter's
and OVKA Kid Kart Director
marc-andre hubert
PostPosted: Fri Nov 16, 2012 6:30 am    Post subject: Reply with quote
Was thinking that as well, was told could be worn cluth hub??????
DB time: 0.198967 (65.5%), total time:0.303781, queries:38
