MaxSpeed - LB
Russell Karting - SS
Quick Pipe question
Kirk Deason
PostPosted: Wed Nov 14, 2012 8:28 am    Post subject: Quick Pipe question Reply with quote
I have an extra exhaust pipe for my PV100 which has a bulge in the middle, slightly different from a regular leopard pipe. Can this pipe be used on a different 100cc motor? Specifically on a 100cc reed valve? Any difference? I know it won't hurt the motor, I am just wondering about the pipe design.
Kirk
John Mulvihill
PostPosted: Wed Nov 14, 2012 12:17 pm    Post subject: Reply with quote
Hi Kirk,
Are there any letters or numbers on the pipe? Usually added by writing with the welder.
Then we can tell you lots.
John
I bowl overhand..........
PostPosted: Wed Nov 14, 2012 9:10 pm    Post subject: Reply with quote
A piston port pipe is allot different than a reed pipe but you could use it if you just want to muffle the engine noise.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
gregg boyce
PostPosted: Thu Nov 15, 2012 8:58 am    Post subject: Reply with quote
Kirk,
We ran the JICA pipe on a Leopard and it worked great! The stock Leopard pipe is basically a muffler whereas the JICA pipe has an expansion chamber (thought small) like RLV pipes for KT100. It definitely helped the Leopard out. Give it a try.
BTW, We spoke to Jim Russell about it and he said "No problem, go for it"
I don't know what the flex was set at though, sorry.
GB
PS-that pipe won't muffle the sound Wink Very Happy
Jim McMahon
PostPosted: Fri Nov 16, 2012 12:41 pm    Post subject: Reply with quote
Yeah if its a JICA pipe it should be fine. Its its some crazy whacko american thing I dont know but we used to swap pipes between the 100cc euro stuff all the time. May not be optimal but it will work safely.
CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online
al nunley
PostPosted: Sun Dec 23, 2012 5:19 pm    Post subject: Reply with quote
post a picture, other wise how will we know.
DB time: 0.15337 (44.93%), total time:0.341365, queries:38
