Acceleration - LB
MG Tires - SS
Franklin / Merlin USA - FB
installing a shifter rod
PostPosted: Fri Nov 16, 2012 9:06 am    Post subject: Reply with quote
If want to all fancy like, take a female rod end on the straight part and attach it to the rod with a jack screw... The rod end can be either left or right depending on which end of the jack screw is in the rod portion Very Happy
I feel another 9 page radiator selection post coming on....
I know, I know, what's a jack screw?????
Personally I run a cable shifter, adjust once, forget it.....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Mike Goebel
PostPosted: Sat Nov 17, 2012 5:52 am    Post subject: Reply with quote
So the left end of the rod gets the left end of the jack screw and the other end of the jack screw is right so it gets a right and then when the jack screw is tuned left or right the left end or the right end gets the left of the right to turn left or right depending on weather the left of right is on the right or left then is on the left rod end gets a right to be on the left or vise a versa the right ends doesn't get the right to be on the right because the left has the right to be on the right and the left doesn't have a right so it can have the right to have a right to be on the right.
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Troy V Smith
PostPosted: Sat Nov 17, 2012 6:30 am    Post subject: Reply with quote
Hey Chris - that's a good idea! I like it. Smile
Mike - good work! That is exactly right, unless it's left or course... Laughing
TVS Motorsports -
"We may not be the fastest on the track...
but we're having the most FUN!"
PostPosted: Sat Nov 17, 2012 10:32 am    Post subject: Reply with quote
Mike G.
Yah, but if you were south of the equator?
Gene Heagney
PostPosted: Sat Nov 17, 2012 5:48 pm    Post subject: Reply with quote
Mike G.
Is this in metric or standard?
Troy V Smith
PostPosted: Sat Nov 17, 2012 6:19 pm    Post subject: Reply with quote
Oh crap! I though we were talking NPT! Start over!
TVS Motorsports -
Cesar Rull
PostPosted: Sun Nov 18, 2012 4:57 pm    Post subject: Reply with quote
I having a problem with clearance.
It seems that no matter what, the rod will hit the seat...
I have a wilkart rod, it has a right hand and a left hand thread.
Take a look at this, this is, Not sure I am missing another piece to the puzzle, or if the rod needs to be bent in two directions but like I mentioned if I only bend the part that goes to the J arm, the rod will touch the seat.
Does anyone have pictures of theirs installed on the CR125?
Sanford Mitz
PostPosted: Sun Nov 18, 2012 5:16 pm    Post subject: Reply with quote
What size is the seat?
Cesar Rull
PostPosted: Sun Nov 18, 2012 5:19 pm    Post subject: Reply with quote
Hi Sanford its a large, on a CRG. Did you get my e-mail?
I need to post some pictures but it keeps getting dark to take some good photos.
Sanford Mitz
PostPosted: Sun Nov 18, 2012 5:29 pm    Post subject: Reply with quote
I've done several CRG's with large seats and Hondas. The black rod in the picture that I sent you was off of one. Is the right hand seat support in the stock position? At most, you might have to put a gentle curve in it, but the one in your drawing is too drastic. Have you installed the seat and put the engine in place with the J arm attached?
Cesar Rull
PostPosted: Sun Nov 18, 2012 5:46 pm    Post subject: Reply with quote
I not sure if the bracket on the right hand support is on the stock position, but the engine is in place with the J arm installed the way it was sent from extreme motorsport (the builder).
I did ask him about sliding the motor away from the seat and he pointed out that it was as far as it could go and the spacers on the motor mount verify this.
I looked at your picture again and I do see a bit of a bend of the black rod.
its very subtle compared to my drawing.
Regarding the seat, it is not installed but it is place supported by the pressure of the brackets and a book under the seat which lines it up with the bottom of the chassis tube...
I have been thinking of installing the seat but up until now, i did not see the rod fitting and working.
PostPosted: Sun Nov 18, 2012 5:54 pm    Post subject: Reply with quote
OK, I've seen it all, a solidworks model of a shift rod? Make sure you do a finite element analysis of the rod!!! Oh, and also a fluid dynamics study as well, you don't want too much aero drag either....
You really shouldn't have to put a second bend in it, if you do, you did something wrong. Most likely the seat is in the wrong place.....
You could model the whole kart and find out what's gone awry..... Very Happy
CR
Sanford Mitz
PostPosted: Sun Nov 18, 2012 5:56 pm    Post subject: Reply with quote
Make one out of a coat hanger or welding rod to simulate positions. Is the lower shift arm pretty close to parallel to the back axle?
Cesar Rull
PostPosted: Sun Nov 18, 2012 6:13 pm    Post subject: Reply with quote
CR
The funny thing is I can do all those things, ,fluid dynamic wouldn't apply to the rod though Wink ... a picture is worth 1000 words.
Like you say maybe I NEED to just install the seat and how things go from there. I would just hate to have re-drill to make the rod fit.
Troy V Smith
PostPosted: Sun Nov 18, 2012 6:16 pm    Post subject: Reply with quote
Laughing
Laughing Obviously, not in your case Cesar - a picture includes a 1000 words! Laughing
TVS Motorsports -
Page 2 of 4
DB time: 0.420168 (59.23%), total time:0.709427, queries:38
