MIR Racewear - LB
Ribtect - SS (non-flash)
installing a shifter rod
Goto page 1, 2, 3, 4  Next
Cesar Rull
PostPosted: Tue Nov 13, 2012 9:54 pm    Post subject: installing a shifter rod Reply with quote
i got a from the guys at shark shifter.
i was told that it would need to be bend to match my kart. The rod looks very sturdy. How are the bent ?, do kart shops have a special rig ?
can someone please post a picture of their shifter rod installed ?
i feel confident installing my seat, but i wonder the order of operation. something tells me i should install the seat first then the rod ?
thanks for the help.
Sanford Mitz
PostPosted: Wed Nov 14, 2012 4:42 am    Post subject: Reply with quote
Yes, install the seat in its proper position first. The rod probably has right and left threads and you may have to shorten it. The rod goes straight past the seat and then takes a gentle bend up to the j arm. So put the engine in place with the j arm attached. Use a coat hanger or piece of welding rod to mock up the bend and any angle, if needed, to get past the seat. Attach the left rod end to the j arm side at the half way point of the threads. Attach the right handed rod end to the bottom of the shift lever and then mark your rod for length after you do the j arm side bend. You will need a right hand 8mm tap to make a new threads iin the rod if you have to shorten it. For bending you can apply some moderate heat and bend in a vise with two pieces of wood in the jaws as not to damage the rod. I've also bent them over unmounted wheels in the past.
Cesar Rull
PostPosted: Wed Nov 14, 2012 5:30 am    Post subject: Reply with quote
Thank you for you reply. Ill post some pics later on in a few days.
Sanford Mitz
PostPosted: Wed Nov 14, 2012 6:29 am    Post subject: Reply with quote
give me your phone number via private email and I'll text you a picture of a bent one.
email=smitz@mrsc.com
Erik Maxfield
PostPosted: Wed Nov 14, 2012 11:24 am    Post subject: Reply with quote
if you have to shorten it, be sure to shorten the side with the RH tapped threads....
Unless you would like to special order a tap (most local hardware stores do not have a LH tap)
(potential "Oh Hell" moment....)
Erik
The early bird gets the worm.....
The second mouse gets the cheese....
Stock CR125.
Chassis-FrankenKART
Intrepid/ITAL combination
Mike Goebel
PostPosted: Wed Nov 14, 2012 6:38 pm    Post subject: Reply with quote
How can you tell which one is the RH thread???
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Erik Maxfield
PostPosted: Wed Nov 14, 2012 7:20 pm    Post subject: Reply with quote
Righty tighty.....
Sheesh, and he is a high falooting NASA/Cosworth/MFG guy....
Rolling Eyes
Laughing
(then again it does not matter much if you have left and right threads once you put a big dog leg in the part.)
Erik
Stock CR125.
Chassis-FrankenKART
Mike Goebel
PostPosted: Wed Nov 14, 2012 9:54 pm    Post subject: Reply with quote
I as just asking the next question for Cesar Laughing
Mike G.
Closet KZ Lover!!!
Erik Maxfield
PostPosted: Wed Nov 14, 2012 10:11 pm    Post subject: Reply with quote
You are sweet on him, eh?
Wink
Erik
Stock CR125.
Chassis-FrankenKART
Michael Taksa
PostPosted: Thu Nov 15, 2012 9:05 am    Post subject: Reply with quote
What's the point of having two different threads on shift link? it's not like you would be adjusting it like the tierod, after it is bent the only way to adjust would be to take the ends of the shifter arm or j-arm. I would go to both RH threads if I was shortening and tapping the threads, unless of course you have some extra LH end lying around you don't know what to do with:)
Michael Boone
PostPosted: Thu Nov 15, 2012 9:30 am    Post subject: Reply with quote
My shifter rod is straight! Wink
If you can't keep up don't worry I'll be coming around again !
KZ 125 Masters
FFSA National race Director
http://www.ask-ancenis.fr/
PostPosted: Thu Nov 15, 2012 11:07 am    Post subject: Reply with quote
That would depend on what rod ends he was sent. The standard ICC shift rod that comes with the kart, or was most likely shipped to him, has a right and left hand thread, so we would have to assume that what rod ends he received also.
Regardless, this is a pretty pointless thread, pun intended....
Michael, if your rod is straight, how do get your suit on? Laughing Laughing
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Sam Zavaglia
PostPosted: Thu Nov 15, 2012 9:04 pm    Post subject: Reply with quote
That is a very good point, the same question I ask myself everytime I do shorten the RH side anyways. Very Happy
I guess it depends if you have more LH or RH rod ends in the spares kit, then again you may need a LH tap if you have an abundance of LH rod ends. Confused
www.samzavaglia.com
Chuck Skowron
PostPosted: Fri Nov 16, 2012 12:03 am    Post subject: Reply with quote
I could see the advantage of having both RH/LH threads, provided the rod is straight. That way, if you need to move the engine slightly fore or aft, you can the adjust the shift rod as well without too much hassle.
But you're right, once you bend the rod that feature does become pretty useless.
C. Skowron
CRG/Spec Honda - 15
Mike Goebel
PostPosted: Fri Nov 16, 2012 6:22 am    Post subject: Reply with quote
I make my own shift rods for my spec moto from 4130 and use right hand threads on both side Shocked
For my ICC I will have to check since I haven't put it on the kart yet Crying or Very sad
Mike G.
Closet KZ Lover!!!
Page 1 of 4
DB time: 0.121975 (42.69%), total time:0.285744, queries:38
