MaxSpeed - LB
Brett King Design
SCCA Enterprises - FB
250 single 5 or 6 speed?
Doug Newhouse
PostPosted: Mon Nov 12, 2012 7:21 am    Post subject: 250 single 5 or 6 speed? Reply with quote
Hello,
wondering about 250 singles classes in the US. 5 or 6 speed gear box, whats the rule?
thanks
Doug
Troy Miller
PostPosted: Mon Nov 12, 2012 3:55 pm    Post subject: Gearboxes Reply with quote
I don't know that there is any specific rule for that. The CR250 Honda is a 5 speed where the 257 Rotax is a 6 speed. Both are legal in the IC/E class for IKF. I am not sure how the WKA classifies them.
Hope this helps.
Doug Newhouse
PostPosted: Tue Nov 13, 2012 4:40 am    Post subject: when do rules publish Reply with quote
thank you Troy,
Anyone...
When do the rules come out for 2013
-IKF
-WKA
others???
Chris Hegar
PostPosted: Tue Nov 13, 2012 3:48 pm    Post subject: Reply with quote
5 speed in the CR Honda in IKF, no mods to allowing for 6 gears in the ICE class is I believe the rule.
www.Hegar4.com
Troy Miller
PostPosted: Tue Nov 13, 2012 5:37 pm    Post subject: Gearbox Reply with quote
Chris is correct.
I received information after my post that the new rule book will have information clearing up any misunderstandings about gearboxes and what can and can't be done with them in the IC/E class.
Doug, the IKF rule book normally comes out in late December / early January. But I am sure you can direct any specific questions to any of the BoD of the IKF and they can answer your questions.
Matthew Walker
PostPosted: Tue Nov 13, 2012 8:12 pm    Post subject: Reply with quote
Unless it's a TRX cos they have a 6 speed tranny Wink
Experience is that marvelous thing that lets you recognise a mistake when you make it again!
Dean Martin
PostPosted: Wed Nov 14, 2012 2:24 am    Post subject: Reply with quote
Rotax 257 is 5 or 6 speed
CR 250 Honda is 5 speed
TRX Honda is 6 speed
IKF Rules 2012 read:
Gearbox - Ratio's are not controlled. Aftermarket parts are allowed.
These rules are expediently in process of being changed to state that Honda CR 250 must remain 5 speed. This is done specifically to exclude the newly completed Viper Racing UK 6 speed kit or any simulary evolving initiatives made to install in to CR 250's.
Doug as you are back east (I think) you should check with local clubs. If you are planning to develop something be sure to clarify the intent of the rules not just the engineering definition of the text.
Hope this helps - DM
DEAN MARTIN
DB time: 0.184883 (46.86%), total time:0.394573, queries:38
