Tim Brown
Posted: Wed Nov 07, 2012 10:00 pm Post subject: Parilla TT75 Pipe |
| Will a RLV RS1 pipe be a good pipe for the Parilla TT75?? or is there a better pipe available? and whats the crank taper, Yamaha or other?... thanks guys Tim... |
Joined: 19 Jul 2002 Posts: 4288 Location: United States, South Jerrrsey,
Posted: Thu Nov 08, 2012 1:19 pm Post subject: |
Crank taper is IAME unless someone muffed it up trying to lap a yamaha clutch on it.
Yamaha KT100 Service Center
40 years karting experience |
Rob Kozakowski
Joined: 05 Apr 2010 Posts: 209 Location: Canada, Alberta, Edmonton
Posted: Mon Nov 19, 2012 7:25 pm Post subject: |
| RS-1 will work good with clutch. Personally, I'd go direct drive though. |
Tim Brown
Posted: Wed Nov 21, 2012 9:13 pm Post subject: |
| I think ur right, I was told that the RS1 had a real narrow powerband and had to slip the clutch at 11k to get there. Whats a great DD pipe for that engine?? Vevey? and what model? I also have the Parilla TT27 Rotary with no pipe...thanks for all the advice guys... |
Bill Martin
Joined: 20 Jul 2001 Posts: 401 Location: United States, California, Escondido
Posted: Thu Nov 22, 2012 1:53 pm Post subject: |
| Tim Brown wrote: | | I think ur right, I was told that the RS1 had a real narrow powerband and had to slip the clutch at 11k to get there. Whats a great DD pipe for that engine?? Vevey? and what model? I also have the Parilla TT27 Rotary with no pipe...thanks for all the advice guys... |
Maybe an RLV DD34? I had/might still have one of those, it seemed to work ok for DD.
bill _________________ Bill Martin |
Jim Russell, Jr. Advertiser
Posted: Fri Nov 23, 2012 7:34 am Post subject: |
The RS1 will work well with an engine clutch. Slip is about 10,00 for best performance. However can be lower.
Any vevey pipe will work for direct drive on either engine.
Check with any local shop to see what they have lying around. Most shops have these items rusting in a back corner. _________________ Russell Karting
888-KARTING |
Rob Kozakowski
Posted: Fri Nov 23, 2012 3:56 pm Post subject: |
| I think I might have an RS-1 "rusting" in my garage that I'd happily part with! |
