Jim McMahon
Joined: 07 Apr 2007 Posts: 2787 Location: United States, St. Paul,
Posted: Wed Nov 07, 2012 11:36 am Post subject: CES 2013 Race Schedule |
Championship Enduro Series 2013 Schedule
May 11th & 12th Gateway Motorsports Park, IL
June 1st & 2nd Blackhawk Farms Raceway, IL
July 13th & 14th Grattan Raceway, MI
Aug 10th & 11th Blackhawk Farms Raceway, IL
Sept 7th & 8th Gingerman Raceway, MI
The 2013 Series will be a two day race format consisting of 10 races at 5 tracks.
Main gates will open on Fridays @ 6:00 pm along with pre-tech and registration.
Each CES Event weekend will consist of two Points races.
Each Event Date is a separate Entry Fee and separate Points race.
All Race Points will be combined as each day is a separate race.
One series champion will be crowned per class.
Your best 8 race finishes of the 10 races will count towards year end Points.
You must compete in a Minimum of 5 Races & be a member of TAG Racing Int. / CES to qualify for series year end awards.
You may also qualify for year end awards by competing in a Minimum of 7 races and paying the event membership fee at each event
You can find the 2013 CES membership form: HERE. Simply fill it out on your computer (yes, really), print it out and send it in. Along with payment of course.
During 2013 and beyond we will be offering online race pre-entry via www.MotorsportReg.com to help streamline the registration process. Accounts are free so you are encouraged to setup an account as soon as possible.
Please join in on the 2013 preseason discussion thread: http://ekartingnews.com/viewtopic.php?t=118555
You can also follow us on FaceBook: www.facebook.com/CESkarting _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online
Last edited by Jim McMahon on Fri Jan 11, 2013 12:10 pm, edited 3 times in total |
Jim McMahon
Posted: Sat Jan 05, 2013 2:47 pm Post subject: |
The dates posted above are no longer tentative and are now CONFIRMED _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online |
Jim McMahon
Posted: Fri Feb 08, 2013 12:12 pm Post subject: |
Memberships are flowing in nicely. Thanks for all the support!
What's great is not only do we have some new names signing up but also some that have been away for a couple of years. Exciting times!
Look for a announcement over the next couple of weeks including the 2012 point standings and the 2013 class structure. _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Jim McMahon
Posted: Thu Mar 28, 2013 6:29 am Post subject: |
Memberships and registration continue to come in as the first race of the season at Gateway approaches.
CES announces two New Classes for the 2013 Season, New race format for LO206 Class.
Sprint Briggs ANIMAL (Class Age 15 years & up – 350 lbs. – Alcohol only – Briggs & Stratton engines. Exhaust silencers required. Aftermarket connecting rods are allowed. Minimum Nose width 38.5”, 5” Wheels only, 450 min front Tires, 600 min Rear Tires, Chain Drive Only, Floor Pan inside frame rails only, sprint style seat only, 14” minimum height cannot pass rear axle. Brake Tether required
ICC-125 Sportsman SPRINT (Class 16) Age 14 years & up -400 lbs. W / 34mm Exhaust Restrictor 360lbs W / 30mm Exhaust Restrictor Gas & oil only – Approved engines: 125cc ICC CIK/FIA engines (ICC engines stock 30mm Delorto carb only) CIK style Bodywork Only. Chassis & engine tech per CES / TAG rules. Tires open Sit-up sprint style seat only, 14” minimum height cannot pass rear axle
Exhaust Restrictors will be available at the events.
Briggs Animal and LO-206 4-cycle classes for 2013 will be sponsored by Briggs and Stratton and will have a new format. These classes will run two 15 minute races instead of one 25 minute race one heat at the beginning of the day and one heat at the end of the day each day that will make these classes a 20 race series counting the best 16 out of twenty finishes for year end points. _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
