KartSport North America - LB
Ribtect - SS (non-flash)
Fuel in airbox
Matt Kalevich
PostPosted: Tue Nov 06, 2012 3:12 pm    Post subject: Fuel in airbox Reply with quote
Leopard/Tillotson Carb/ KG Cobra Intake
I notice when doing my post track cleanup of the kart, that there is a bit of fuel sitting at the bottom of my KG Cobra Intake and it leaks out the bottom at times. I always open up the intake and clean it. I tend to run the kart rich and conservative and can imagine fuel going into the box, but I am just being cautious to ensure that something is not wrong.
Appreciate the help guys!
-Matt
Tony Kart Krypton/MY09 Leopard
jeff grose
PostPosted: Tue Nov 06, 2012 3:53 pm    Post subject: Reply with quote
yep, i had the same in our leopard, by the way, i was advised by those for more knowledgeable than me to ditch that cobra airbox and run the standard leopard airbox and i did, motor seemed to be more responsive to fine tuning with the standard airbox than with the cobra airbox Smile
jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Matt Kalevich
PostPosted: Tue Nov 06, 2012 3:55 pm    Post subject: Reply with quote
Thanks Jeff! Do you have fuel move into the stock box as well?
jeff grose
PostPosted: Tue Nov 06, 2012 8:33 pm    Post subject: Reply with quote
still have a little but you're gonna have there one way or the other,especially if you tend to run real rich on 1 or both needles, i'm at work now but if I think about it i'll send you my needle settings tomorrow, of course you probably won't want to set yours as close,,,,,,,,,,, Wink
jlgracing
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Matt Kalevich
PostPosted: Tue Nov 06, 2012 8:40 pm    Post subject: Reply with quote
Thanks Jeff. Shoot me a PM with the needle settings if you remember. I start both at 1.5 and tune down slowly throughout the day. Just hate getting close to too lean...that and I am still learning a lot on the track.
Also it looks like we arent far from each other if you are in Cocoa. OKC is my home track and live not too far (520/528-Wedgefield). Always trying to meet up and make new track friends! I have yet to see another Leopard at OKC haha
-Matt
Paul Makarucha
PostPosted: Wed Nov 07, 2012 6:06 am    Post subject: Reply with quote
13/4 to 2 on the low, 7/8 on the high
Normal to have a bit of fuel in the box, but, as far as ditching the cobra box, I'm personally not a fan either, but if you resort back to the stock box keep in mind you are losing some air inlet opening. The cobra box has... I don't remember 30mm openings? and the stock leopard box as 28mm? openings or something. I.E. less air, marginally less power to be made.
Also I'd run a filter in the stock box if you run a stock box.
edit: My memory for air inlet openings is crap
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Oscar Biondi
PostPosted: Wed Nov 07, 2012 11:40 am    Post subject: Reply with quote
You can get the cobra box with either 23mm or 30mm inlets.
DB time: 0.336021 (47.53%), total time:0.706965, queries:38
