Acceleration - LB
MRP - SS
Tony Kart/Vortex - FB
Clutch Drum won't turn after tighten nut
Todd Renaud
PostPosted: Sat Nov 03, 2012 9:34 pm    Post subject: Clutch Drum won't turn after tighten nut Reply with quote
Switching from a 11-tooth driver gear to the 12-tooth on a new style clutch for the first time using parts that came with the engine when I bought it used. When I tighten the hex nut to keep the clutch drum on, the drum won't turn freely anymore. I am using the thrust washer, the o-ring and the needle bearing cage. If I install all that without the o-ring, it spins fine.
Doing a little research - it seems that the needle bearing that I have might be longer than the 2010 kit that comes with the o-ring. Is the newer one (needle bearing) shorter?
Thanks.
Marshall Martin
PostPosted: Sun Nov 04, 2012 4:04 am    Post subject: Reply with quote
Try it without the oring. You might have a pre-O'ring needle bearing which would explain the issue.
Marshall Martin
LSR Motorsports
www.lsrmotorsports.com
marshall@lsrmotorsports.com
Todd Renaud
PostPosted: Sun Nov 04, 2012 6:44 am    Post subject: Reply with quote
It works without the o-ring which is what I wanted to confirm was that the Pre and post o-ring kit had different bearings. Thanks.
Chris McGinley
PostPosted: Sun Nov 04, 2012 12:36 pm    Post subject: Reply with quote
Yes, the needle bearing is different pre vs post o-ring. If you're using the pre o-ring needle bearing, I'm sure that's the problem. The new needle bearing leaves enough room in the driver gear for the o-ring to fit without interfering much with the bearing.
Chris McGinley
Monster Raceworks
Rotax Masters
http://www.njkarting.org
http://www.btbsecurity.com
DB time: 0.138911 (43.18%), total time:0.321717, queries:38
