KartSport North America - LB
MG Tires - SS
Franklin / Merlin USA - FB
Winter storage.
Michael Taksa
PostPosted: Fri Nov 02, 2012 8:56 am    Post subject: Winter storage. Reply with quote
Just how exaclty do you fog a motor for winter storage, CR125? Pour an ounce or so of oil (which one?) in sprak plug hole and give it a spin? Other then draining water and gearbox oil anything else? Besides draining the carb of course. My seals on the water pump went bad after a winter once, anything I can do to "lube" them?
Thank You.
Greg Lindahl
PostPosted: Fri Nov 02, 2012 10:38 am    Post subject: Reply with quote
Drain fuel from kart/engine.
Change oil in gearbox.
Remove engine and double bag in garbage bags.
Store in house/apartment.
PostPosted: Sun Nov 04, 2012 11:01 pm    Post subject: Reply with quote
Don't leave castor oil or pump gas (ethanol) in the motor. I mix a 1/2 pint of 32:1 Homelite oil with a few cap fulls of Marvel Mystery oil mixed in and let my engine idle/smoke on that. Leaves preservative oil on everything that sees gas.
If you want to dump MMO in the plug hole make sure your exhaust port is closed first so the oil will spread out evenly before you prop it over. 1/2 an ounce is plenty.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
PostPosted: Mon Nov 05, 2012 5:52 am    Post subject: Reply with quote
What Walt said^ Also, pull the water pump cover off, drain off the water and spray some WD40 in there. Water gets trapped in there and will either rust the the plate or could freeze if you store in a cold place. I would pull the drain on the jug also, blow through the head pipes to make sure there's no water in there.
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Jeff DeMello
PostPosted: Mon Nov 05, 2012 6:28 am    Post subject: Reply with quote
Run 50/50 anti freeze in it. It also lubricates the water pump seals and no chance for any cracks in the cases if all the water was not removed
Jeff DeMello
Emmick F125 Pavesi
Benn Herr
PostPosted: Mon Nov 05, 2012 8:14 am    Post subject: Reply with quote
What is this "anti freeze" you speak of?
Why don't you just keep racing year round?
Oh that's right, you have WINTER!
Hah! (insert evil laugh here) Laughing Laughing Laughing
Our most recent race (October 28th) started at 4:30 in the afternoon at 83 degrees.
Next race, November 25th.
Soloution to Winter storage - Move to Arizona! Cool
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
PostPosted: Mon Nov 05, 2012 8:31 am    Post subject: Reply with quote
Ha Ha Benn....
You didn't tell him that in the summer his engine will overheat before he even starts it Wink
Eight years of 115* summers was enough for me. You can dress for the cold at least Laughing
Cheers,
Heartbeat Power, LLC.
Michael Taksa
PostPosted: Mon Nov 05, 2012 8:38 am    Post subject: Reply with quote
Thank You guys, very informative, will do all of the above, and then still store it in a room where it's not cold:) Well all of the above except running it with oil mix, too late for that, motor is off the kart.
Brian Mead
PostPosted: Mon Nov 05, 2012 7:10 pm    Post subject: Reply with quote
John - not to highjack the thread but, 115 ? Not 105 ? 115 ? What do you do in the summer besides pay outragous electric bills to get the temp down below 100?
Benn Herr
PostPosted: Mon Nov 05, 2012 7:20 pm    Post subject: Reply with quote
Actually it got to 122 a few years ago.
But that's outside.
We don't go outside.
You race at night after the sun goes down.
Or you travel to some of those nice cool tracks farther north.
Three months of too much sunshine is worth it so you can wear shorts at Christmas time. Cool
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
PostPosted: Mon Nov 05, 2012 7:21 pm    Post subject: Reply with quote
It's Dryyyyyy heat!!! Very Happy
CR
Benn Herr
PostPosted: Mon Nov 05, 2012 7:26 pm    Post subject: Reply with quote
CR
The humidity makes a big difference. This Summer was miserable, the humidity was over 20 percent almost all of August. When it's dry (less than 5 percent) you can be out in 105 heat with very little discomfort. Plus the metal in your shop doesn't get all rusty - or exhaust pipes!
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
Tim Doll
PostPosted: Mon Nov 05, 2012 9:37 pm    Post subject: Reply with quote
+1 (or is it +2 Laughing ) on the Marvel Mystery Oil. That stuff is amazing and won't gum up over time. I had a spare engine that had been 'preserved' with MMO then sat in my trailer for a couple years (i.e. outside, not bagged or anything like that). I suddenly needed to use it - pulled the head and barrel to check it out but everything looked perfect. Aside from a bunch of smoke when I started it up, it ran perfectly and I won the race.
Tim
Standard disclaimer - I'm FREE - No longer affiliated with any organization, I can say whatever I darn well please!.
Everett, Washington
DB time: 0.117182 (26.1%), total time:0.448893, queries:38
