MIR Racewear - LB
Leading Edge Motorsports
Why didn't Rotary ever catch on?
Goto page 1, 2, 3, 4, 5  Next
Justin Martin
PostPosted: Sun Oct 28, 2012 12:23 pm    Post subject: Why didn't Rotary ever catch on? Reply with quote
Hey all. As many o you know I am new, again, to Karting. After a break of 7 years I am back and racing Rotax Sr.
The Rotary has always intrigued me, especially when there was the Rotary kart motor. It seemed so promising with its consistent powerband, low end torque, and low operating costs (almost no rebuilds!). So why didn't this ever catch on? Seems to me it would be a great TaG motor. Instead we keep going for these high reving, high maintenance kart motors which just makes the karting industry more and more expensive! Looking at it from the motorcycle world, karting has always been expensive!
I would appreciate any more experienced insight to this question.
Thanks all,
Justin
PostPosted: Sun Oct 28, 2012 1:25 pm    Post subject: Reply with quote
The Aixro is a very cool motor but makes Rotax look cheap. Also, way too much power for all but the best drivers and they're mostly running shifters. The running costs might be lower but the rebuilds sure aren't and you don't want to know what happens when you break it Crying or Very sad
There are a few of them running competitively in UAS though.
Cheers,
Heartbeat Power, LLC.
Brian G. Wilson
PostPosted: Sun Oct 28, 2012 2:22 pm    Post subject: Reply with quote
I have to disagree with John as I run an Aixro rotary. Just out of curiousity, and this is a serious question as I honestly don't know, how much does a new Rotax cost? On the Rotax, I'm guessing if you bought the motor, carb and pipe as a package you are going to be in the $5K range? The Aixro comes complete with the motor, carb, pipe and motor mount for under $6,500.
I have put tons of hours on my Aixro without a single motor related issue. The carb comes from the factory set the way you need it, I have never changed jets no matter what kind of heat/humidity/cold I have run in. Between runs, I literally lube the chain as soon as I come in and refuel if necessary and just let it sit there until the next run. Last time I went to the track and they were running us 10 minutes on and then 10 minutes off while the rentals ran, my friend and I rotated 10 minute sessions from 9 AM until after 2 PM and never missed a 10 minute session. I would come in, he would lube the chain and top off the fuel while I cooled down and then he would suit up and go for the next session and vice versa all day......couple of guys made the comment they wish they could do that with their karts. Kart never skipped a beat and we were both beat at the end of the day. Read the manual and operate it as they dictate (within the rpm's, bearing & water temps they suggest) and you should have no problem.
As far as the rebuild go, they suggest every 100 hours to open it up and replace a few small items. My rebuild at 100 hours cost me less than $200, including labor. At 300 hours, they suggest putting in new main bearing, but the total with labor should still be less than $4-500.
I think if you ran a Rotax, shifter (take your choice of stock moto or ICC) and an Aixro side by side for a season or two, the Aixro would come out ahead as far as maintenance time or cost involved. There are a couple of guys that I know of that run them and we've all had the same experience.
KEEP WORKING....millions of people on welfare depend on you !!
PostPosted: Sun Oct 28, 2012 3:07 pm    Post subject: Reply with quote
Leopard package, 3k. Aixro 6.5k. Maybe over time it evens out with maintenance costs, but it's hard to plop down that much cash for most people.
I'd love for them to be the class of choice, it seems like an awesome package. But so expensive initially.
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Brian G. Wilson
PostPosted: Sun Oct 28, 2012 3:29 pm    Post subject: Reply with quote
I will say the Aixro is not the perfect, end all, be all package. At some smaller, tighter tracks, the Rotax is faster, then again, they're also faster than the shifters. They have a series that runs them in the UK and it is gaining popularity by leaps and bounds and they grid 10+ Aixro's each race and run MG Red's as the spec tire. The Aixro is also not good on long road courses with huge straights as it can't be held at WOT for more than 10-12 seconds at a time. Not a problem for me as I don't think I've ever had the occasion on any course less than 2 miles in length to hold it at WOT for more than 5-6 seconds before the next corner came up.
Ok, so the Leopard is $3k, is that the same as the Rotax? I keep hearing about this passport thing with the Rotax which sounds like you can't do the rebuilds yourself. Anyways, how many hours or seasons do you get out of a Leopard or Rotax before you buy a new engine? What is the resale value on them? How many total hours do you put on your engine a year, between track days, practice and racing?
Unfortunately, the Aixro is regarded as an illegal engine by the WKA. Therefore, any event that is sanctioned by the WKA won't allow you to run it and until that changes, they don't have much of a chance of becoming popular where the WKA is the dominant sanctioning body.
Paul Makarucha
PostPosted: Sun Oct 28, 2012 4:25 pm    Post subject: Reply with quote
Are the apex seals on the Aixro on the rotor itself?
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Brian G. Wilson
PostPosted: Sun Oct 28, 2012 4:42 pm    Post subject: Reply with quote
Yes, I believe they are on the rotors, but I can't confirm that as I am not a mechanic and haven't personally opened mine up.
Justin Martin
PostPosted: Sun Oct 28, 2012 6:01 pm    Post subject: Reply with quote
Cheers,
I agree with Brian. Everything he said is everything I have heard about them. Great shifter or TaG motors.
Rebuilds would be super cheap. If you rebuild a rotax as suggested it is $750+ every 30 hours!
A Rotax cost an initial of $3,600 complete. After 4 rebuilds you are at the running costs of a Rotary. After that it is nothing but loss. Not to mention at 4 rebuilds its about time for a new cylinder and the engine is just about worn out, time for a new engine.
Sounds to me that if the market were bigger the Rotary would come down in price and be ideal for both shifter classes and TaG.
The only thing I don't like about the rotary is the oil bypass, which limits the 12 second WOT, however that would rarely even matter!
Chris Hurst
PostPosted: Sun Oct 28, 2012 7:03 pm    Post subject: Reply with quote
Can anyone explain to me how you can put apex seals on anything but the rotor itself? Never heard of that before.
PostPosted: Sun Oct 28, 2012 7:20 pm    Post subject: Reply with quote
Justin I had the same question as you when I read about it. Then I drove one and for the life of me I don't see why they haven't taken off in the US. On most tracks they'll compete with a shifter. An icredible power band almost no specific power band at all. They claim 50 hours between rebuilds you would think it would be looked at as the answer. I came very close to buying one there just isn't anyone racing them in my area.
Justin Martin
PostPosted: Sun Oct 28, 2012 7:56 pm    Post subject: Reply with quote
You can't lol
Brian, I totally agree.
If you ask me the karting world is a bit corupt. Don't get me wrong, I love karting more than my first love (motorcycles), however sometimes the expenses just don't make sense! I truely wish the rotary would catch on. It makes so much sense. If they want a spec class that allows drivers to compete on skill, then rotary is a great option. They are trying SPEC classes with rotax and such, but unfortunately to he competitive it cost insane amount of Mont finding that "race motor" the constant rebuilds etc.... If they just got a reliable motor brought down costs and reduced rebuilds then karting would come back to spec, and really poor the poor skilled drivers in the same league as wealthy skilled drivers.
The money vs power thing is what killed my love for racing motos, and I thought karting was more "spec" but because of the rebuild costs, and the fact people go through 6+ motors to find the one with the "edge" no longer makes it spec! Lol
I know the entry costs of rotary are expensive, however I believe with popularity and reduced operating costs it would eventually lower the over all price!
PostPosted: Mon Oct 29, 2012 4:55 am    Post subject: Reply with quote
A lot of it doesn't make sense to me. Rotax runs a while between rebulds but you can't do the work yourself. Box stock is now a chinese copy of a Honda that needs to be built before it's competitive. It should be a Honda GX200 with the governer removed bolted on to a kart but it's not. Kid karts run Comer's can anyone explain to me why a kart for the 5-7 year old range needs a $1000 2 stroke engine? Why not a simple cheap 4 stroke?
It seems like the governing bodies have paid more attention to the manufactures and dealers than the end user. It's much more complex and expensive than it needs to be.
PostPosted: Mon Oct 29, 2012 7:06 am    Post subject: Reply with quote
The question I was trying to answer was why didn't it catch on.
I had the good fortune to check them out when first introduced and it looked like a great thing. Although we were an early dealer it was a hard sell at the price point and we couldn't move any of them at that time, especially with the clutch issues. Sounds like they've gotten the early challenges straightened out but I still think it's too much power for most kart racers.
But if you really want to know why some things hit and others don't just follow the money going to national organizations, how many pipes are there for KT100 now? Laughing
Cheers,
Brian G. Wilson
PostPosted: Mon Oct 29, 2012 7:29 am    Post subject: Reply with quote
Maybe the Aixro will gain a little more popularity in the US with the introduction of the new motor, the XR30. As I understand it, it is the XR50 that has been fitted with a smaller carb w/restrictor plate and rev limited to 10,000 rpm. It still has the same power curve, but only at 30 hp. The 30 hp XR30 can be turned into the 50 hp XR50 by installing the proper size carb, removing the restrictor plate and 10,000 rpm rev limiter. You say the XR50 has too much hp, buy the XR30 and convert it to the XR50 in the future if you'd like more hp.
PostPosted: Mon Oct 29, 2012 7:40 am    Post subject: Reply with quote
It's an awesome idea for an engine, but like I said, shelling out almost 7k for a go-kart engine all at once is pretty tough for most.
When KF came out, everyone said it was too expensive at 5k for the engine too. That's a big reason it never caught on here.
I think at most you are looking at 3.5k for a new engine package, as a price point that karters would be willing to spend. That's what Rotax is and obviously it's quite successful.
T.J. Koyen
Exprit/Leopard
Page 1 of 5
DB time: 0.213547 (43.33%), total time:0.492847, queries:38
