Aaron Witzke
Posted: Fri Oct 26, 2012 4:58 pm Post subject: Motul Kart VS 800 2T oil |
I work at a motorcycle dealership, and would like to take advantage of the fact I can get Motul for cheap. The P/O of my kart was using the Motul Kart oil, which he gave me one bottle of. I searched around a bit, and found a lot of kart sites that sell the 800 2T oil. What would be (if any) the benefit of running the kart specific oil over a motorycle road racing 2 stroke oil? If I do go with the 800 2T Motul, would the mix ratio be the same (16:1)?
Thanks |
marc-andre hubert
Posted: Fri Oct 26, 2012 5:12 pm Post subject: |
| i run the 800 2t in my 125cc shifter 7oz/gal 110 vp leaded |
Aaron Witzke
Posted: Fri Oct 26, 2012 5:23 pm Post subject: |
Do you run the offroad or the road racing version? I'd presume the road racing one might be a better choice? The description Motul has is identical for both.
| Quote: | | 100% synthetic lubricant based on Double-Ester-Technology. Specially designed for Road racing premix 2 stroke engines operating at high revs and under high load. Very high lubricating properties decrease friction and wear. Keeps engines and exhaust power valves always well lubricated. Prevents piston rings and exhaust power valves from sticking. For premix only! |
marc-andre hubert
Posted: Fri Oct 26, 2012 6:56 pm Post subject: |
| i got offroad |
Aaron Witzke
Posted: Sat Oct 27, 2012 7:38 pm Post subject: |
Anyone else have any input regarding this? I'd like to order a few cases as more = lower cost and don't want to buy something I'll end up regretting.
For the record, I am running a Leopard. |
Jeff Salak
Joined: 01 Aug 2007 Posts: 624 Location: United States, Illinois, Antioch
Posted: Sat Oct 27, 2012 8:28 pm Post subject: |
I see no problem for practice.
If you plan on racing? Might want to check your local clubs rules and see what spec oil they use for a Leopard. |
Riley Will
Joined: 03 Sep 2001 Posts: 1361 Location: Canada, not USA state,
Posted: Sat Oct 27, 2012 8:41 pm Post subject: |
Kart was designed for high revving 100cc engines, it's perfect for your Leopard at your current ratio! _________________ Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com |
Aaron Witzke
Posted: Sat Oct 27, 2012 10:38 pm Post subject: |
I don't see any spec oil listed.
Riley, I am inquiring regarding using the Motul 800 2T Road Race oil (motorcycle). I know the Kart oil is good but unfortunately can not get it through work.
I know lots of two stroke m/c racers rev to the moon, and find it hard to believe that a road racing oil would not be OK, but I am not an oil analyst... and new to karting hence why I am asking the question. The cost savings is substantial, so it makes a difference. |
Riley Will
Posted: Sun Oct 28, 2012 12:05 am Post subject: |
800 is all I use up here. Used it for years on ICA. Now use it on our 150's and 250cc twins. It's great for your application. _________________ Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com |
Aaron Witzke
Posted: Tue Oct 30, 2012 10:15 am Post subject: |
| Upon looking through my book again today, I see I can get belray gk2 kart oil. |
