OTK - LB
SCCA Enterprises - FB
Stock appearing TT75 question/HELP
RON LAX
PostPosted: Mon Oct 22, 2012 4:33 pm    Post subject: Stock appearing TT75 question/HELP Reply with quote
Can amyone give me specs on port timing/heights on stock appearing TT75????
Will going below 9 cc work well?
ideas on squish???
Any solid info will be greatly appreciated!!!
karter9907@yahoo.com thanks!!!!!
Oscar Aguilera
PostPosted: Mon Oct 22, 2012 9:03 pm    Post subject: Reply with quote
sounds like you need a good motor builder? dont know where you are so cant help you much to send you in the right direction.
RON LAX
PostPosted: Mon Oct 22, 2012 9:15 pm    Post subject: Reply with quote
I have two motors that are different...so i am looking for what might be average settings.Roadrace...gas...S4...hr191 carbs... Idea
RON LAX
PostPosted: Mon Oct 22, 2012 9:16 pm    Post subject: Reply with quote
al nunley
PostPosted: Tue Oct 23, 2012 3:56 am    Post subject: Reply with quote
Going bigger/higher, on the ports, is always worth more HP. The higher, the bigger, (same thing) the higher the clutch slip RPM.
Compression increases are always good, if you can control the detonatio. The EGT will help with that.
With gas, you’re limited by octane. The higher the compression, the more octane you need.
I found, with the K78, that less ignition timing was good.
PostPosted: Tue Oct 30, 2012 10:48 am    Post subject: Reply with quote
VPC12, RLV DS1 pipe, 9cc head, 15 degree squish .032 clearance, .090" btdc ignition, 16K, piston skirt clearance .005". The only porting you could do is to widen the boost port, very labor intensive for small gain, you need to pull the liner out twice and make sure you leave enough cylinder wall for the piston ring gap/pin. 191 carb needs lots of work but one thing is file a small groove in the throttle plate where the low jet is to help draw fuel when off throttle. Pumper stack on top not side or bottom.
Hope that helps,
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Mark Horne
PostPosted: Fri Nov 02, 2012 4:36 am    Post subject: Reply with quote
Ron, I sent you a PM.
SLK PowerLab
2 Cycle Dyno Tuning
"Racing is life,.....everything else is just waiting"
Steve McQueen - LeMans
"There are only two things that make feel alive, racing is one of them." Smile
al nunley
PostPosted: Fri Nov 02, 2012 8:35 am    Post subject: Reply with quote
Steve, I raced stock foreign back in 1977 and we used high octane pump gas, but there was no race gas that I know of in those days. I also ran less timing, .060” BTDC. I won the Championship that year and got 2nd at the Atwater Nationals. Ran direct drive.
I still think I should have gotten first place. Culver did the winning engine and the transfer passages were really worked over. And this was a “stock” class.
DB time: 0.185354 (63.22%), total time:0.293182, queries:38
