SKUSA (non-flash) - LB
MG Tires - SS
Leading Edge Motorsports
chilly premix
Andy Kiker
PostPosted: Thu Oct 25, 2012 11:40 am    Post subject: Reply with quote
Ian, Glad to see you back to your usual self. Very Happy
I see you or someone took off the four corners of the piston.
I also had to start doing this with the Honda when I ran it.
Just curious as to why? Did not seem to have to do it until we started turning it above 11,000. Any correlation?
Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad
al nunley
PostPosted: Thu Oct 25, 2012 12:29 pm    Post subject: Reply with quote
Would like to see a picture of that piston from the top. Even a close up of the head. Do I see detonation on the edge of it? That edge has the look of “sandblasting”. That’s what detonation looks like.
Detonation is caused by excessive heat and/or pressure.
The reason you get peak EGT reading at peak RPM is because that is where the cylinder pressure is the least. The 2cycle reaches peak pressure at peak torque, and that is why you need to watch the EGT coming off the corners. Even thou the EGT reading is less at that point, you can still get detonation if the pressure and/or temperature is above the fuels ability to resist it, caused by a lean mixture. It’s no secret that the KT runs best with a rich low speed mixture.
If the pipe is right, it can produce pressures, at low speed RPM’s, above the fuels ability to handle.
Doesn’t it stand to reason that peak torque is reached with peak pressure in the cylinder.
Racer Johnson
PostPosted: Thu Oct 25, 2012 4:46 pm    Post subject: Reply with quote
AL I gotta be honest sometimes when i read your posts I feel like im on LSD..... Surprised
Ian Harrison
PostPosted: Thu Oct 25, 2012 5:27 pm    Post subject: Reply with quote
Hi Guys
Well spotted, Andy!! This was a brand new A cylinder at the start of the meeting, so I cross-hatched the corners with 120's production paper. This gives a little extra in clearance and retains a bit more oil. It's all about the temperature of the piston (i.e. expansion). The higher the revs and the longer you stay on the gas the bigger the piston gets. So the higher revs we use now do put things closer to the edge. I'd say I did a good job as you can see the vertical polish lines have almost obliterated the cross hatch right on the corners and also the 2 x polished "eyes" on the front lower skirt. Without the hatching that piston may well have stuck. After a new cylinder has had 3 pistons through it, I don't cross-hatch any more (with standard Honda 'A' pistons). It can make the exhaust port-bridge scuffing a little heavier in the crankcase induction Honda and encourage rear cracking on the cylinder induction.
Hi Ted, your reply is actually closer to topic tha Al's . . . . well done matey Wink
Hi Al, I'll do a picture when I get to work tomorrow. No det. but right on the limit. 60 taps on the det counter and that's spot on for me in a 35kM race. Suddenly, a change of tack, no comment regarding "gumming" , which, I thought was the topic? but a load of "so what!!!!!" regarding cylinder pressure and KT100's (I guess?). Silly me I thought this was a 250 Superkart Forum. Nobodys attacking you here, just stating a few facts. . . . ease of that throttle a bit and relax Laughing Laughing Laughing
Of course it's as dry as a knat's scrotum in line with the transfer windows and round the back half. I'll say it again, that's the only way to run with unleaded Laughing
Eric, I know what you mean . . . . sort of surreal . . . peace and love man Confused Cool
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Ian Harrison
PostPosted: Fri Oct 26, 2012 12:57 am    Post subject: Reply with quote
Hi Al
Just for you!!
No det . . . . smooth as a babies bottom . . . . but absolutely right on "the nuts" Cool
OH . . . and still no gumming *"%:&^!
Heres a twin straight off the dyno on Avgas 100LL and Castrol A747 Castor.
Not as much running, but just as nice Cool
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Sam Zavaglia
PostPosted: Fri Oct 26, 2012 5:17 am    Post subject: Reply with quote
Ian Harrison wrote:
Hi Al
Just for you!!
But now the inlet side looks like detonation.
Can you take another picture and post it here so we can be sure?
Ian, when your ready to add that SZR light to the HRC det counter, the driver can tell you when it was activated, off the corners (max torque/max pressure) or down the straight (max revs/lean main jet), then you can comeback on here and reply to Al.
Anyway, I like olive oil better than bean oil, however Elf oil is the best.
Al is right though, he is talking about KT100, they are iron bore not nicasil, beans would be a treat on iron bores. Wink
www.samzavaglia.com
Ian Harrison
PostPosted: Fri Oct 26, 2012 6:15 am    Post subject: Reply with quote
Hmmmm, Sam, A bit of Al reply anticipation going on there. Just surprised you didn't comment on the missing rear cylinder bolt on the SAFE Wink
Sam Zavaglia wrote:
Can you take another picture and post it here so we can be sure? NO!! but I can post the piston to Al so he can take a look/feel for himself. Rolling Eyes
Ian, when your ready to add that SZR light to the HRC det counter, the driver can tell you when it was activated, off the corners (max torque/max pressure) or down the straight (max revs/lean main jet), then you can comeback on here and reply to Al. What do you mean, WHEN?? I have been desperate for months, can you even remember what I want including the ones for the bikes as well. No panic now anytime your ready. Cool Anyway, when did I ever have a driver who looked at the gauges and lights . . . I'll be taking my info off the logger. . . much more reliable
Anyway, I like olive oil better than bean oil, however Elf oil is the best. Cool
Al is right though, he is talking about KT100, they are iron bore not nicasil, beans would be a treat on iron bores. Wink I always cook my baked beans in a cast iron pan, perhaps that's the same thing Rolling Eyes
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
PostPosted: Fri Oct 26, 2012 8:50 am    Post subject: Reply with quote
So true for both!!! With the Mychron data, you will know EXACTLY where and when the deto occurs... If you haven't already, you might want to add a throttle position sensor on an extra channel, that would also be very useful....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Ian Harrison
PostPosted: Fri Oct 26, 2012 9:26 am    Post subject: Reply with quote
Hi Chris
Yes that's the plan once Sam gets the detto harness made, I'll be wiring in the TPS on the Mikuni TMX as well.
I'm just waiting for the first "I really was flat in top through there". . . . in your dreams, perhaps Wink
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Sam Zavaglia
PostPosted: Sat Oct 27, 2012 3:30 am    Post subject: Reply with quote
I'll get the harness for HRC det counter made to plug and play into your MyChron logger plus a warning light for your drivers by end of next week. Deto LED intensity will be set to burn drivers eyeballs.
Let me know if you need help to make the TPS logged as well.
Back to topic, I think that Elf oil is better than bean oil if it's chili. Wink
www.samzavaglia.com
Gerry MacNutt
PostPosted: Sat Oct 27, 2012 9:59 am    Post subject: Reply with quote
ELF does not sell oil on the west coast of USA or Canada, or at least I've never seen it for sale.
PostPosted: Sat Oct 27, 2012 11:58 am    Post subject: Reply with quote
ELF 976
http://ekartingnews.com/viewtopic.php?t=116179&start=0&postdays=0&postorder=asc&highlight=
Aaron Stanford wrote:
IF YOU NEED ELF 976 OIL STILL LET ME KNOW.
CAN GET YOU WHAT EVER YOU NEED.
AARON
CR
Ian Harrison
PostPosted: Sat Oct 27, 2012 6:07 pm    Post subject: Reply with quote
Sam Zavaglia wrote:
I'll get the harness for HRC det counter made to plug and play into your MyChron logger plus a warning light for your drivers by end of next week. Deto LED intensity will be set to burn drivers eyeballs Cool Sam, no panic. I can pay you in money or Ignitechs Wink
Let me know if you need help to make the TPS logged as well. Should be OK on that one, I'll just make up a seperate sensor lead to plug into a 4-pin analogue channel . . . unless you got the Honda socket for the TPS, then you can do it for me . . . . or I could send you the sensor with it's flying lead and you could fit your favourite plug and socket!! (I'll e-mail an image of the plug) Cool
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Gerry MacNutt
PostPosted: Sat Oct 27, 2012 9:15 pm    Post subject: Reply with quote
OK, maybe better put, ELF is not highly available at most retail outlets on the westcoast, for what ever reason.
Chris
thanks for the tip!
Gerry MacNutt
PostPosted: Sun Nov 11, 2012 10:55 am    Post subject: Reply with quote
update, temp was around 32 (burr) in the morning, I ended up using Motul 800 roadrace, seemed to work good , motor was making real good power.
Page 2 of 3
DB time: 0.165099 (35.9%), total time:0.459921, queries:38
