OTK - LB
Streeter - SS
KG Plastics - FB
What is the fuel of choice for a Stock Moto CR125?
Goto page 1, 2  Next
Derek Lodato
PostPosted: Sun Oct 21, 2012 8:13 pm    Post subject: What is the fuel of choice for a Stock Moto CR125? Reply with quote
I'm trying to figure out the best fuel to use or my SRS built '99 CR125 Stock Moto engine
Also, What type of fuel container should I store AND transport the fuel: Plastic or Steel container and why?
Ryan Leger
PostPosted: Sun Oct 21, 2012 8:22 pm    Post subject: Reply with quote
Ms98 or c12 if im correct i run c12 and ms98 in mine
Derek Lodato
PostPosted: Sun Oct 21, 2012 8:28 pm    Post subject: Reply with quote
I am in Florida so VP Fuel is not an option .... Any other options?
Ryan Leger
PostPosted: Sun Oct 21, 2012 8:54 pm    Post subject: Reply with quote
Sory from canada why cant you run vp there possibly sunoco race fuel
Derek Lodato
PostPosted: Sun Oct 21, 2012 9:19 pm    Post subject: Reply with quote
I meant its not readily accessible .....Thanks for your input
al nunley
PostPosted: Mon Oct 22, 2012 5:30 am    Post subject: Reply with quote
Let's go the other way; what are your choices in your area.
Jim McMahon
PostPosted: Mon Oct 22, 2012 5:40 am    Post subject: Reply with quote
Are you asking about practice or racing? Bottom line is you want something that is 96MON at the minimum if you want to avoid detonation.
Sealed steel container for longer term storage, plastic is OK for a weekend, steel would be preferable.
/Edit.... Did you ask John at SRS? I think he "might" just have a couple of ideas on fuel for you too Wink.
CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online
marc-andre hubert
PostPosted: Mon Oct 22, 2012 8:13 am    Post subject: Reply with quote
im in fort myers and can get VP 3 shops within 5 miles,i run 110 leaded with 7to1 motul runs awesome. you need to come race at racecomplex.com awesome track we need more shifters.
Jason Berry
Advertiser
Advertiser
PostPosted: Mon Oct 22, 2012 10:09 am    Post subject: Stock Moto Fuel Reply with quote
SKUSA requires the VP MS98 fuel for competition. This has been a good fuel choice for the Stock Moto Engine. If you are using other fuel or a replacement, contact each fuel supplier for their specs.
We have 3 options in NorCal for a 98 octane fuel. Of the three, VP MS98 does not cause detonation. The other two require much richer jetting.
Most fuel suppliers offer a 5 gallon steel pail. Only mix enough fuel and oil for the day.
www.shopswedetech.com
www.swedetechracing.com
www.swedetechracing.com/news-events-blog/
www.facebook.com/Swedetech
marc-andre hubert
PostPosted: Mon Oct 22, 2012 10:24 am    Post subject: Reply with quote
Florida winter tour is also ms98.. i have only ran the 110 with zero issues do you know if switching to ms98 will affect the jetting alot, i would up the jet size to start but just asking
Spencer Uzri
PostPosted: Mon Oct 22, 2012 12:58 pm    Post subject: Reply with quote
Depends on "aggressive" your current jetting is. Engine compression volume is a factor to consider. Stock ICC/KZ spec is 13 cc vol @ TDC, higher than a moto, which is 10-11 cc @ TDC (I think). More vol. mitigates det., but still, if you're jetting is particularly lean then you may need to size up when switching to lower octane fuel.
Jim McMahon
PostPosted: Mon Oct 22, 2012 1:13 pm    Post subject: Reply with quote
The changes in jetting are more to do with the specific gravity of the fuels than its octane rating.
Cesar Rull
PostPosted: Mon Oct 22, 2012 8:06 pm    Post subject: Reply with quote
Interesting thread. I just contacted my engine builder (also just purchased a Cr125 stock). He mentions 110 octane race gas. Is that the same as what you guys are talking about?
MS98 ?
I am in south florida, what are my fuel choices. Sorry for the stupid question but are these fuels available at any gas station?
Jim McMahon
PostPosted: Mon Oct 22, 2012 8:22 pm    Post subject: Reply with quote
Its not usually available at a gas station. At least not the VP stuff. Some places might have 100leaded on pump. There's a few different methods of calculating Octane. I like to use MON. MS98 is 98octane by the most common method (R+M/2), it's MON is 96. You could try a google maps search for "race gas" in your area and see what crops up.
Long story short, 110 (by any method) will be fine. You will be leaving a little power on the table, but thats not a big issue at his point. One thing that's good about the higher octane leaded fuels is that the extra lead is very kind to bearings and so forth, so from that perspective they are perfect when you are looking to get seat time and have maximum reliability. That might be the basis of the recommendation.
Cesar Rull
PostPosted: Tue Oct 23, 2012 1:42 am    Post subject: Reply with quote
so do I just go to any gas station that sell race gas 110 octane and buy some? Then mix it with castor oil and I am good to go?
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.194843 (48.17%), total time:0.404501, queries:38
