SoCal Sprinters
Ribtect - SS (non-flash)
Tony Kart/Vortex - FB
EGT Sensor on CR125 placement.
Goto page 1, 2  Next
Cesar Rull
PostPosted: Thu Oct 18, 2012 10:04 pm    Post subject: EGT Sensor on CR125 placement. Reply with quote
I found the following thread with very good information.
http://www.ekartingnews.com/viewtopic.php?t=67680&sid=40ffdd96c340754a423383e7c7686186
I wonder though it is applies to a honda engine considering the pipe is not straight and rather shaped like a horn.
Does anyone have any pictures they can share on how they installed their EGT on a CR125 application?
Does the CR125 pipes RLV R4 for instance have enough diameter for an AIM egt probe?
Tyson Henry
PostPosted: Fri Oct 19, 2012 6:05 am    Post subject: Reply with quote
Certainly you saw this thread:
http://www.ekartingnews.com/viewtopic.php?t=118060
Live without an EGT.
al nunley
PostPosted: Fri Oct 19, 2012 9:50 am    Post subject: Re: EGT Sensor on CR125 placement. Reply with quote
My advice stays the same, look where others are placing their’s and match your’s to that.
Exact positioning is only important when you want to comare your readings to others. Be sure the tip of the probe is in the same postion too. The best place for the tip is always in the center of the flow.
John Mulvihill
PostPosted: Fri Oct 19, 2012 10:04 am    Post subject: Reply with quote
Good info in those posts.
Braze a nut on the outside of the pipe. Brazing a nut rather than welding will put less stress into the sheet steel. The Mychron sensor will protrude about 1/2" inside, which will be fine.
I usually drill a 1/4" hole for the fitting and hold it in place with a cotter pin while brazing. Run a tap through the hole after everything cools.
The tiny nuts are a pain to braze or weld. I usually make my own mounting nuts by cutting a piece of 1/2" steel rod about 1/4" long, drilling and tapping.
Used crank plugs from a KT100 are perfect for this and Free.
The steel in the outside curve of a pipe is going to be the thinnest due to stretching. Not the best place to weld a fitting.
Tie down the sensor wire so it doesn't stress anything due to vibration.
No other words of wisdom to add.<LOL>
John
I bowl overhand..........
Cesar Rull
PostPosted: Fri Oct 19, 2012 3:54 pm    Post subject: Reply with quote
I would use an O2 sensor but I was told they are not legal...
Well I guess its back to water temp only for now. I mean I guess EGT would be good to keep an eye on things..
Mike Goebel
PostPosted: Fri Oct 19, 2012 6:26 pm    Post subject: Reply with quote
Just put a
Main 175
Pilot 55
In it and forget it!!
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Cesar Rull
PostPosted: Fri Oct 19, 2012 9:14 pm    Post subject: Reply with quote
Mike what you referring you. I am sorry I am not following.
al nunley
PostPosted: Sat Oct 20, 2012 7:06 am    Post subject: Reply with quote
An O2 sensor is nice, but with oil in the fuel, there are other problems.
CHT?? Just about worthless. Not quite, but very near.
One jet fits all??? What about air density??
Jim McMahon
PostPosted: Sat Oct 20, 2012 8:29 am    Post subject: Reply with quote
If you wanted you could have a second pipe for testing with a wideband sensor in it. A plain ole O2 probably isnt going to switch fast enough. Get a battery on there to power the heater and it shuold last about 5hrs before it gets ruined. You would get some very valuable data from it. Of course you would need to log air density too, throttle/slide position probably wouldn't be a bad idea either.
To start off though, air density gauge along with piston crown/header check is where you should start IMO. Use EGT to compliment it if you like.
Mike is referring to jet sizes.
Oscar Biondi
PostPosted: Sat Oct 20, 2012 8:41 am    Post subject: Reply with quote
Jim McMahon wrote:
If you wanted you could have a second pipe for testing... .
+1
The supatuna gauge/O2 sensor works great. Developed by a kart racer for 2-stroke engines. Dave is a really nice guy too.
http://www.airtimeproducts.com.au/assets/docs/SUPA-TUNA%20ManualV4small.pdf
joseph hollinger
PostPosted: Sat Oct 20, 2012 9:53 am    Post subject: Reply with quote
I tried that with a TAG motor. Ran fine in road race where we use unleaded. Died in one session on the sprint track with MS98L.
Cesar Rull
PostPosted: Sat Oct 20, 2012 10:37 am    Post subject: Reply with quote
thats not good, those boch sensors are expensive aren't they? I have never had to replace one on a car. But you guys bring up a good point.
Aim did tell me about the second pipe for tuning which some people do.
I think that a club level though it wouldn't a big deal if I have the sensor were in there, but in my case I don't have a battery.
BTW then O2 goes on the pipe? as in on the RLV R4 pipe... I better find me a used one if I am going to need two pipe for this to work.
Oscar Biondi
PostPosted: Sat Oct 20, 2012 11:21 am    Post subject: Reply with quote
You can buy two-wire O2 sensors for $10 bucks on clearance all the time on Rockauto. Usually made in Japan. They don't last forever but will last for a long time as long as you don't run too rich. You also have to remove the probe shield to make them work better. I've used them with a Leopard and work great.
joseph hollinger
PostPosted: Sat Oct 20, 2012 11:53 am    Post subject: Reply with quote
With leaded gas?
Oscar Biondi
PostPosted: Sat Oct 20, 2012 12:05 pm    Post subject: Reply with quote
Yes, I've only used it with leaded gas.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.129926 (46.49%), total time:0.279443, queries:38
