Troy V Smith
Joined: 07 Nov 2010 Posts: 180 Location: United States, Louisiana, Morgan City
Posted: Wed Oct 17, 2012 11:01 am Post subject: RLV R4 and EGT... |
Not to beat a dead horse, but continuation from a previous post...
I've got an issue with another R4 pipe cracking. I have been told that the cause of the crack is most likely caused due to the heat generated from welding the EGT bung onto the pipe. This first pipe cracked in the very same place, and the EGT bung was welded in the very same place. Now that the second pipe is cracked, I am looking for other options and a solution to the problem.
Where are others attaching the EGT bung onto their pipes - are there others that have had this same issue? Just looking for a solution which will utilize the EGT, but not present further problems in the future. Maybe a different EGT location, different way of fixing the bung to the pipe, different materials or process? Although the crack cause has been identified by RLV, I have not been presented with a "fix" or suggestion to prevent it from happening again.
I realize the pipe can be "fixed" but doesn't do me much good to "fix" it, if the same problem will arise again? And how is one supposed to "weld" the crack, if the heat from a "weld" caused the problem in the first place?
Looking for suggestions in achieving a working RLV R4 pipe with EGT bung in place without resulting in a busted pipe? Lot’s of folks out there using a R4 and EGT without issues – what’s the secret? Can anyone reccomend a good, experienced welder, which can yield better long term results. I think the welder I use does great work, but will certainly try another if better results can be achieved.
Thanks to All...
 _________________ TVS Motorsports -
"We may not be the fastest on the track...
but we're having the most FUN!" |
Ken Schilling
Posted: Wed Oct 17, 2012 4:58 pm Post subject: |
From the responses on the other thread it looks like brazing the bung in place is the solution as welding creates too much heat... _________________ Ken Schilling
SKUSA Data Administrator
The opinions I express are mine alone and do not reflect those of any organization of which I am a member. |
Troy V Smith
Posted: Wed Oct 17, 2012 5:47 pm Post subject: |
Is there any indication that one side of the pipe would be better than the other? As it is now, i use the bottom, outside of the pipe - would there be any less stress created by using the outside of the pipe - closer to the seat? Hate to bug people about their EGT bungs, but geeze - got to make sure I do everything I can to avoid buying another. _________________ TVS Motorsports -
joseph hollinger
Joined: 12 Sep 2002 Posts: 9468 Location: United States, California, san francisco
Posted: Wed Oct 17, 2012 7:09 pm Post subject: |
Who needs an EGT on s shifter? _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
Ken Schilling
Posted: Wed Oct 17, 2012 7:17 pm Post subject: |
| joseph hollinger wrote: | | Who needs an EGT on s shifter? |
Certainly not me, I'm only a SKUSA mid-pack runner right now, but most of the SKUSA Spec Honda drivers don't use an EGT anyway... _________________ Ken Schilling
joseph hollinger
Posted: Wed Oct 17, 2012 7:22 pm Post subject: |
I think that's generally true. I used one briefly when I started out, but mostly because I was used to it from TAG. Seems to be pretty rare in stock moto. _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
Mike Goebel
Joined: 28 Jul 2001 Posts: 5763 Location: United States, California, Winnetka
Posted: Wed Oct 17, 2012 8:07 pm Post subject: |
Why doesn't the pipe break from just being welded together
And don't say they heat treat them after welding
mfg Technology Centre
Kerry Matthews
Joined: 01 Oct 2008 Posts: 772 Location: United States, California, Sacramento
Posted: Wed Oct 17, 2012 11:21 pm Post subject: |
| Ken Schilling wrote: | | joseph hollinger wrote: | | Who needs an EGT on s shifter? |
Certainly not me, I'm only a SKUSA mid-pack runner right now, but most of the SKUSA Spec Honda drivers don't use an EGT anyway... |
Well, I'm slower than BOTH of you guys, and I use an EGT sensor. Probably like Joe, I was used to it from TaG, so I kept using them.
It's one of the tools that helps me to decide what jets to use. Not a critical item, but still a tool, nonetheless.
And yes, the bung needs to be brazed onto the pipe. _________________ Play now, work later! |
Cesar Rull
Posted: Fri Oct 19, 2012 3:53 pm Post subject: |
| good information ! |
Erik Maxfield
Joined: 16 May 2004 Posts: 1068 Location: United States, California, Vacaville
Posted: Sat Oct 20, 2012 8:47 pm Post subject: |
I have brazed mine for years with no problems.
I am one of the oddballs that use EGT. I road race (wth Joe and Kerry). I use the information for tweaking my jetting program. _________________ Erik
The early bird gets the worm.....
The second mouse gets the cheese....
Stock CR125.
Chassis-FrankenKART
Intrepid/ITAL combination |
Joined: 29 Aug 2002 Posts: 2918 Location: United States, New York, Ossining
Posted: Sun Oct 21, 2012 5:32 am Post subject: |
| Mike Goebel wrote: |
Mike G. |
Actually, they are gas welded which is self "normalizing".....
and who says they don't crack????
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com |
Mike Goebel
Posted: Sun Oct 21, 2012 7:38 am Post subject: |
| Chris Reinhardt wrote: |
CR |
RLV told me they TIG weld the R4 pipe
Posted: Sun Oct 21, 2012 7:46 am Post subject: |
| Mike Goebel wrote: | RLV told me they TIG weld the R4 pipe
Mike G. |
They lied!
They look gas welded to me, unless the newer/cracked stuff in now tig'd.... _________________ East Coast Super Kart Series
al nunley
Posted: Sun Oct 21, 2012 10:38 am Post subject: |
| Chris Reinhardt wrote: | | Mike Goebel wrote: | RLV told me they TIG weld the R4 pipe
Mike G. |
They lied!
They look gas welded to me, unless the newer/cracked stuff in now tig'd.... |
Gas or Tig, makes little difference in mild steel. _________________ If the data does not support the theory, get a new theory. (Al Nunley)
Mike Goebel
Posted: Sun Oct 21, 2012 1:16 pm Post subject: |
They lied! |
That's what I thought
