MIR Racewear - LB
Russell Karting - SS
SCCA Enterprises - FB
PRD Fireball Starter removal
Lawrence Doty
PostPosted: Mon Oct 15, 2012 6:36 pm    Post subject: PRD Fireball Starter removal Reply with quote
Take out the 2 cap screws (Bolts) and the motor should just slide out correct? I'd rather ask than find out the hard way I needed to do something else...
Battery is still good, tried a new out of the box one I have.
Push the start button and the only thing that happens is the relay clicks. Connections all seam to be good.
I think the grandson holds the start button down too long and...hopefully it just needs new brushes...
Motor starts with an external starter.
Lawrence Doty
PostPosted: Tue Oct 16, 2012 5:30 pm    Post subject: Reply with quote
Hmmmmm....starter on my truck just left me stranded at work...last week it was flat tires...this week it's starters...I can't wait for next week... Rolling Eyes
Rob Bartley
PostPosted: Tue Nov 06, 2012 5:24 pm    Post subject: Reply with quote
Yes two bolts and it slides out, or was it three? Either way you might have to tug a little to break it free but your on the right track
#3 Gillard Charlotte / PRD
Lawrence Doty
PostPosted: Thu Nov 15, 2012 7:45 pm    Post subject: Reply with quote
2 bolts, thanks for the response.
The reason I asked was because I saw the o-ring and just wanted to insure it wasn't there for more than just dust/dirt...
As it turned out it was more than the brushes...once I got the housing off a bunch of...something...fell out. Starter is toast... Luckily I have a back-up.
Anyone know if a starter from a leopard (I think that's the right one???) will work on a PRD? They "look" identical and are almost half the price...
Johnathan Green
PostPosted: Thu Nov 15, 2012 9:49 pm    Post subject: Reply with quote
The starters are different but Mattoon Machine makes a setup to run a leopard starter in a PRD so you can use the better and less expensive starters. Even with their setup its still cheaper than buying a new PRD starter!
DB time: 0.170894 (48.96%), total time:0.349032, queries:38
