bruce Kapanke
Joined: 08 Sep 2006 Posts: 175 Location: United States, Wisconsin,
Posted: Fri Oct 12, 2012 5:25 pm Post subject: Old RoK question |
Picked up a kart with an older ROK motor on it-has the ICC type looking silencer. New battery- turns over-will not start. Has spark/170lbs. compression(??)/ does not seem to draw fuel from carb-even poured a a little fuel in cyl. no pop even.
There is a tube that comes off of the case-does not connect to anything. Any help or suggestions would be much appreciated. |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2678 Location: United States, St. Paul,
Posted: Fri Oct 12, 2012 7:40 pm Post subject: |
What carb is on it? Pumper or Dell'orto slide? If its the latter the loose pipe might be for a fuel pump that hopefully you are not missing.
Pics? _________________ Live in the midwest and have a TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart?
Ryon Beachner Advertiser
Posted: Fri Oct 12, 2012 11:49 pm Post subject: |
The loose pipe you are referring to is the vacuum line that controls the pulse which actuates the fuel pump. If the fuel pump is still present, reconnect the hose to the metal spigot on the pump. Once done, put a new spark plug in it, make sure it's primed, pull the choke lever up, and it should start after a couple turns.
These engines originally shipped with a dellorto pump, and are very low maintenance as long as everything is routed correctly and the carburettor has a hole in the vent tube.
If you need any help, feel free to contact me at the shop. _________________ 2Wild Karting
www.2wildkarting.com
Shop: (949) 206-9906 |
