JIM SILVERHEELS
Posted: Fri Oct 12, 2012 4:42 pm Post subject: Opinion on front brakes |
Is there a significant advantage using a kart with front brakes please? thanks _________________ Don't get stuck in someone else's discarded chewing gum with your thought process. |
Paul Makarucha
Joined: 11 Jun 2002 Posts: 859 Location: United States, New Jersey,
Posted: Fri Oct 12, 2012 4:53 pm Post subject: |
Short answer is no. In anything less than a shifterkart they simply scrub off too much speed too quickly. Because they are so capable you either enter the corner too slow, or you enter with the chassis binding up because the front brakes are fighting the chassis trying to work during turning the kart into the corner.
I have a friend that does decent with them on for TAG because he dials pretty much all the front brake out of the system. They only drag when fully on the brakes, as soon as he's diving into the corner, even if he's trail braking a bit the fronts will be 'off', allowing the chassis to work.
That said... I can out brake him with only rear brakes into every corner... _________________ CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Do you have any special rituals when the helmet is concerned like many have? - "I wipe it so that I can see better." - Kimi |
Adi RocK
Posted: Fri Oct 12, 2012 5:02 pm Post subject: Re: Opinion on front brakes |
| JIM SILVERHEELS wrote: | | significant advantage |
Of cuz, Yes |
Justin Martin
Posted: Fri Oct 12, 2012 5:32 pm Post subject: |
| I personally believe it improves your cornering speed to only drive with rear brake. In technical sections I smoke shifters with my rotax. They get me back on the straights usually. |
Jim White
Posted: Fri Oct 12, 2012 6:52 pm Post subject: |
My experience road racing with a 100cc Yamaha kart:
I was always very good under braking with rear only. When I added fronts I found that I could brake harder and the kart wouldn't get as "tail happy" at the limit as with rear only. After a few races though I realized that the little bit of "tail happy" that I lost was keeping me from getting the kart to rotate as I turned in. "Chassis bind" as someone else said earlier could be the reason but I really didn't think that deep about it at the time. I took them off and the kart was just as fast as it always had been and it felt better driving it at the limit brake wise.
Now on my 100cc ICA Reedjet powered kart the added speed into the corners made me rely much more on the front brakes. That kart was very narrow and much more of a "point and squirt" so to speak than the Yamaha which relied on keeping up momentum. I don't think I'd run it without the fronts.
I think the answer you are looking for depends on your kart/engine combo, what type of racing you do and most importantly your style of driving.  |
Justin Martin
Posted: Fri Oct 12, 2012 8:03 pm Post subject: |
| Very true. I know in Rotax it benefits to keep the RPMs up and the rear end a bit loose. I also agree with chassis binding. |
Oscar Aguilera
Posted: Sat Oct 13, 2012 7:23 am Post subject: |
all modern vehicles have front brakes...and a motorcycle is lost without them...there is a clear advantage in braking with full 4 wheel brakes....however
if the car or kart you are driving has very little acceleration...not enough motor...you will have to use the brakes as little as possible. so with less braking required the front brakes work.....too good for the amount of braking needed to slow the car or kart down.
drivers tend to abuse the brakes by using them too much...
but remember when all things are even....the only two places a driver can out perform another is his ability to stop and his ability to accelerate...as quoted from my memory of aryton sennas driving principles book. you ability to slow the kart down as little as possible is always the goal whether you have front brakes on not. braking later than someone else has to compliment accelerating out of the corner better than the other guy.
so imo the hp of the motor dictates the necessity of front brakes...until you get to a 125 shifter with the added weight,,, i dont believe front brakes are needed to cut the best lap time. on some tracks it may be an advantage for one or two particular corners, but then you have to look at overall advantage with lap times. or an ability to pass while racing.
new castle comes to mind with the long straight. front brakes should help if the driver can minimize braking on the other corners. or has the presence to back them off with the adjustment knob and then roll more front brake down the straight, but that is alot to ask from a driver. i have never done that but it could be done.
just my opinion |
Cesar Rull
Posted: Sat Oct 13, 2012 8:09 pm Post subject: |
Are the brakes 50/50 on shifter karts usually?
.. I forgot to subscribe. |
Oscar Aguilera
Posted: Sun Oct 14, 2012 7:52 am Post subject: |
if your brake system is in perfect working condition with good fresh new fluid...i turn the dial to put a little more front brake.
i will hold the pedal down till the fronts lock up and with the same brake pressure i will turn the knob adjuster till the rears can barely be turned with alot of force.
but when pads wear,,,fluid is old you might have to adjust accordingly. you have to get a feel for what the brakes are doing on the track and adjust from there.
you can adjust to the point that the rears barely lock up and then turn the knob anywhere from 1-3 complete turns to the front bias depending on how sensitive you like your brakes. because with too much front brake the kart will get twitchy and possibly pull to one side with very slight steering input or if you start trying to turn and are still on the brakes.
if the track has a bumpy surface in the brake area,,,you will notice it more.
it is harder to tell if you have too much front brake than too much rear...so on the track i might put too much rear and tune from there.
just my opinion |
Brent Harper
Joined: 30 Mar 2003 Posts: 892 Location: United States, Texas, Lubbock
Posted: Mon Oct 15, 2012 7:53 pm Post subject: |
We do pretty well with them. _________________ SWISS HUTLESS SWISS I/CMC ROTAX |
John Savage
Joined: 30 Jan 2002 Posts: 1252 Location: United Kingdom (Great Britain), not USA state,
Posted: Mon Oct 15, 2012 11:22 pm Post subject: |
Front brakes are faster BUT they really add to the cost of a kart which in today's hard times is already too expensive for a lot of karters, if the governing bodies exclude them then we all benefit and no one loses out _________________ Dellorto, Mikuni and Keihin Jetting & Kart Set-up Software
www.rotaxjetting.com www.kartsetupsoftware.com |
