MIR Racewear - LB
MRP - SS
SCCA Enterprises - FB
Axle size
Bill Schmidt
PostPosted: Wed Oct 10, 2012 10:29 am    Post subject: Axle size Reply with quote
Curiously, was anyone that ran Solo Nats running anything other than a 50mm rear axle? I was running a 1 3/8" (35mm), so I know that I was the exception.
Bill Schmidt
'88 Red Devil F500 4-link rear (Rotax)
James Newman
PostPosted: Wed Oct 10, 2012 10:35 am    Post subject: Reply with quote
Clements runs a 35 or 30. Nutpack are all 40's iirc. Lower's are 40.
#35 AS, SCCA WDCR
Joe Ricard
PostPosted: Wed Oct 10, 2012 12:12 pm    Post subject: Reply with quote
I had or have a 40 on my ICC. SKM "C" or hard axle. with long 140MM hubs.
Now running a Medium axle with short hubs for our track.
Parking lots were always slick.
Track is grippy enough to push the front end on the hard axle.
Arrow AX-8/ Rotax Sr.
Bill Schmidt
PostPosted: Wed Oct 10, 2012 7:28 pm    Post subject: Reply with quote
I know the Hills and Langenfeld all have 50s
Bill Schmidt
Larry MacLeod
PostPosted: Wed Oct 10, 2012 7:51 pm    Post subject: Reply with quote
I bent 2 different 40mm axles at Nationals.
F125 #196
Lefty Funk
Detroit Region
Bill Schmidt
PostPosted: Wed Oct 10, 2012 8:06 pm    Post subject: Reply with quote
Larry,
Is there a 50mm axle in your future? Or just a harder 40mm?
Bill Schmidt
Larry MacLeod
PostPosted: Thu Oct 11, 2012 4:07 am    Post subject: Reply with quote
Bill Schmidt wrote:
Larry,
If I go 50, it'll be with an all new chassis. But I think the 40 is perfectly competitive.
I normally run the hardest axle you can buy. But I bent it 2 weeks before Nationals. The only replacement I could get was a medium. I bent that on the test course on Monday in Lincoln. Then I borrowed Lisa Garfield's medium and bent that on the East Course on Wednesday.
Moral of the story - don't hit cones, they bend axles.
Larry
F125 #196
Lefty Funk
Detroit Region
Joe Ricard
PostPosted: Thu Oct 11, 2012 8:51 am    Post subject: Reply with quote
Something I discovered after I bent an axle is shifter kart axles in the 50mm size are reenforcedunder the drive sprocket. I guess because the wall thickeness is less than the 40mm variety.
DB time: 0.137646 (41.7%), total time:0.330056, queries:38
