Joe Ricard
Joined: 23 Jun 2009 Posts: 868 Location: United States, Mississippi,
Posted: Thu Oct 11, 2012 7:54 am Post subject: |
Mike is "smoches" a technical term? _________________ Arrow AX-8/ Rotax Sr. |
Mike Goebel
Posted: Thu Oct 11, 2012 8:14 am Post subject: |
| Joe Ricard wrote: | | Mike is "smoches" a technical term? |
Yes I was hoping that the high level terminology didn't go over anyone's head
mfg Technology Centre
Tim Doll
Joined: 18 Jul 2001 Posts: 2643 Location: United States, Washington,
Posted: Thu Oct 11, 2012 10:49 am Post subject: |
I'd suggest bead blasting (tiny glass beads) rather than sand blasting. Not only does bead blasting avoid the rough surface Mr. Helmet noted, it's less likely to add/change local stresses in the frame.
Everett, Washington |
Posted: Thu Oct 11, 2012 1:32 pm Post subject: |
you've got to blast with the right abrasive. Very fine for a kart frame that gives you a surface that's about like 400 grit paper. That will get you a good tooth but won't require a big build up of coating to be smooth. BTW never blast the floor pan it's to thin you'll distort it.
Floor pan and seat are ready assembly this weekend!!!
Joined: 29 Aug 2002 Posts: 2929 Location: United States, New York, Ossining
Posted: Thu Oct 11, 2012 3:59 pm Post subject: |
| Brian Degulis wrote: | | you've got to blast with the right abrasive. Very fine for a kart frame that gives you a surface that's about like 400 grit paper. That will get you a good tooth but won't require a big build up of coating to be smooth. BTW never blast the floor pan it's to thin you'll distort it. |
Exactly.... If it's been powder coated prior, some guys will chemical strip first, then blast. Mike, that's probably why it came out rough, they went with an aggressive media to strip the old Powder off it... They even have fillers and primers that work with powder coating.....
BTW anybody on the East coast, I would suggest Anthony Brothers Powder Coating: http://www.anthonybrospowdercoating.com/
Jim does excellent work, and is very, very reasonable....
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com |
Scott Heavin
Joined: 18 Oct 2006 Posts: 1766 Location: United States, Indiana, New Castle
Posted: Fri Oct 12, 2012 3:30 am Post subject: |
Sprayed mine with truck bed liner. It's at least as tough as powdercoat, if not tougher. It does come out a little rough, but a quick sanding with some 400 grit smooths it out and makes it easier to clean.
Unfortunately, most paints nowadays just flat out suck becasue of all the new environmental regs. Especially rattlecan paints. _________________ Spec TaG Masters @ NCMP / #23 |
Posted: Fri Oct 12, 2012 4:45 am Post subject: |
Yeah spray bombs aren't very good. The problem I see is that karts are normally done with automitve paint and it's just not adequete on a kart that's going to to be wiped with cleaning solvents stepped on etc. As I said earlier marine and industrial coatings like Awlgrip work very well in all respects.
Brian |
Posted: Fri Oct 12, 2012 5:36 pm Post subject: |
Brian, that stuff sounds like a great find, but you have to be careful where you spray it, and use a good respirator also... I'm guessing you don't live in California, if they caught you, they would just shoot you!!!
And your neighbors must love you!!!!
jeff grose
Joined: 11 Dec 2008 Posts: 1249 Location: United States, Florida, cocoa
Posted: Fri Oct 12, 2012 5:47 pm Post subject: |
He even painted the seat  _________________ jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Remember: "No matter where you go,there you are" |
Mike Goebel
Posted: Fri Oct 12, 2012 5:57 pm Post subject: |
| Chris Reinhardt wrote: | I'm guessing you don't live in California, if they caught you, they would just shoot you!!!
CR |
That's not true, we don't have any guns!!!!
Posted: Fri Oct 12, 2012 8:17 pm Post subject: |
| Mike Goebel wrote: | That's not true, we don't have any guns!!!!
Mike G. |
I'm sorry, they would just Rodney King you.....
Jason Bane
Joined: 01 Aug 2009 Posts: 277 Location: United States, Alabama, Gadsden
Posted: Fri Oct 12, 2012 8:50 pm Post subject: |
| Look into DuraCoat. It is ultra tough, very durable, and resists chemicals used to clean firearms (similar to brake cleaner). I did a frame with it last year, turned out great. I will likely refinish my current kart over the winter. |
Posted: Sat Oct 13, 2012 5:34 am Post subject: |
| Chris Reinhardt wrote: | Brian, that stuff sounds like a great find, but you have to be careful where you spray it, and use a good respirator also... I'm guessing you don't live in California, if they caught you, they would just shoot you!!!
CR |
I live in FL where we shoot back.
BTW Mineral spirts is a great alternative to brake cleaner. It cleans just as well leaves no residue and it's easier on you and your paint a lot cheaper also. You can't get it in spray cans but a chemical resistant spray bottle works great.
Brian |
Cesar Rull
Posted: Sat Oct 13, 2012 4:13 pm Post subject: |
^ that right, you do live in FL. (I looked at the lake behind your house and the palms.)
So where do you live so I come over and help you (and you can help me) paint my fame !!
I am trying to figure out how to remove the rear axle....
I noticed the cassette is sort of like a clamp, I guess that is how it attaches to the bearing. Then the bearing's inner race seems to be attached to the axle with some set screws.
so if I want to remove the axle, I am thinking I should assemble everything back to the chassis and remove the setscrews I mentioned and start tapping the axle from one end of the kart through each cassette? or is there a better way to do this?
My motivation for wanting to paint the chassis, the previous user scraped the bottom bare to the metal in some areas and I am worried about it rusting and they getting all messed up and having to buy a new frame. (considering I just bought this kart as my first kart) |
Scott Heavin
Posted: Sat Oct 13, 2012 6:14 pm Post subject: |
| Cesar Rull wrote: | ^ that right, you do live in FL. (I looked at the lake behind your house and the palms.)
Pretty much. It's usually easier to remove the axle while the cassettes are attached to the frame. Make sure you loosen all the set screws - including the rotor carrier and water pump pulley (just remove the sprocket carrier if it's outboard). I always like to lube the axle to help it through the bearings. Then gently tap it out. That's the ideal method. I've had to use a 5 lbs. sledge to get axles out before. I mean like take a full swing & beat the crap out of it while someone else holds the kart on the stand. Just depends... _________________ Spec TaG Masters @ NCMP / #23 |
