Ace Rossi
Joined: 12 Feb 2011 Posts: 221 Location: United States, Florida,
Posted: Sat Oct 06, 2012 5:21 pm Post subject: Tony Kart help |
A good racing friend of mine runs a Tony kart that is a shifter snd equipped with a TM k9.
The kart is loose and he has changed EVERYTHING trying to get rear grip and it doesn't matter what changes are made NOTHING shows as any difference. He's tried air pressure, caster, camber, toe, rear width, front width, new tires, old tires even different brand of tires. He's tried torsion bars in, out, flat and vertical, together and separate! Still nothing! He's beginning to get very discouraged and I'm afraid he might sell out if he cant find some rear grip! He doesn't race competively but wants to IF he can figure out this problem. He can actually use up a brand new set if MG yellows to where they are trash on a practice day at OGP!
Does anyone have any ideas that he hasn't tried or someone in our local area that might want to help the next time we hit the track?
Thanks |
Randy Mckee
Posted: Sat Oct 06, 2012 5:40 pm Post subject: |
The lack of response to changes that you describe can be caused by an incorrect seat position.
Has he tried moving the seat? That is by far the biggest change you can make to any kart setup. Moving the seat (and hence weight) will usually increase grip on that end.
Also, has your friend scaled the thing? If not, try to do that first and then move the seat to attain the manufacturers spec. As a general rule, 57% to 59% weight at the rear is a good starting point.
Be sure to do some searches on seat placement and/or scaling the kart. There's quite a number of things you have to check to make sure it's reasonably close. _________________ Randy
#123 TonyKart - S4 Stock Honda |
Ryon Beachner Advertiser
Posted: Mon Oct 08, 2012 9:24 pm Post subject: |
Ace,
Before I can recommend anything, I need to know what model, and what year the chassis is that your friend has. _________________ 2Wild Karting
www.2wildkarting.com
Shop: (949) 206-9906 |
Alex King
Joined: 01 Mar 2004 Posts: 929 Location: United States, California, OC
Posted: Tue Oct 09, 2012 12:14 am Post subject: |
Ace - give 2WildKarting a call, they are the authority as an OTK TonyKart Shop. I haven't tried this, but they may even accept collect calls from the east coast. For Premier Series-A services, let them know that Brazilian Superstar Alex King sent you there and ask to speak directly with 'Cowboy'. Good luck!
2Wild Karting
Mike Goebel
Joined: 28 Jul 2001 Posts: 5766 Location: United States, California, Winnetka
Posted: Tue Oct 09, 2012 7:41 am Post subject: |
It's probably his right foot
mfg Technology Centre
Joined: 19 Jul 2002 Posts: 4301 Location: United States, South Jerrrsey,
Posted: Tue Oct 09, 2012 1:39 pm Post subject: |
Probably another guy who jumped into a high powered kart to soon. Just tell him to put a factory base line set up on it then drive it slower and he'll get lower lap times.
Funny story, I saw a guy at the track that would go way off into the dirt coming off of every turn no exaggeration dirt dust grass flying everywhere. Later in the pits I heard him bragging that he could take every corner flat out full throttle. Funny to watch but if you were driving anywhere close to him you would get hay fever from the ton of flora he dragged back on the track.
Yamaha KT100 Service Center
40 years karting experience |
jeff grose
Joined: 11 Dec 2008 Posts: 1249 Location: United States, Florida, cocoa
Posted: Tue Oct 09, 2012 1:51 pm Post subject: |
Ace
you're telling me your friend has practiced at OGP and they can't help him w/Tonykart issues That place is OTK heaven, you can't swing a dead cat w/o hitting a Tonykart there. _________________ jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Remember: "No matter where you go,there you are" |
Ace Rossi
Posted: Tue Oct 09, 2012 1:53 pm Post subject: |
"Probably another guy who jumped into a high powered kart to soon"
First off I think this remark was uncalled for since you have no idea who the person is! Id personally like to see how YOU drive!
I came here asking for help to help another racer! If thats your way of helping, remind me never to race near or around you if its anything close to your helpfulness, it isnt much!
Now rather than say you saw a guy, why not just fess up that it was yourself!
We call people like you NDSOB's! Im sure you have some sense to figure that out! |
Mike Goebel
Posted: Tue Oct 09, 2012 2:23 pm Post subject: |
| jeff grose wrote: | | That place is OTK heaven, you can't swing a dead cat w/o hitting a Tonykart there. |
insert helmet here -- >
jeff grose
Posted: Tue Oct 09, 2012 3:37 pm Post subject: |
Mike G.[/quote]
Resist the URGE Mike  _________________ jlgracing
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Posted: Tue Oct 09, 2012 6:26 pm Post subject: |
| Ace Rossi wrote: | "Probably another guy who jumped into a high powered kart to soon"
Not to pile on, but if your friend has changed everything and has the same issue it's either three things: driver, seat position, or cracked frame.
I don't think Walt is being out of line here, honestly, driver is almost always the issue when it comes to this sort of thing, especially when it comes to a kart with as much power as an ICC.
No one is trying to rag on your friend, we're just simply stating a common issue.
So is the seat in the right place? _________________ T.J. Koyen
www.oktanevisual.com
Exprit/Leopard |
Steve O'Hara
Joined: 02 Jan 2002 Posts: 1063 Location: United States, California,
Posted: Tue Oct 09, 2012 11:31 pm Post subject: |
Ace,
I've seen other posts by you on these forums so I hope I'm correct in my assumption that you have a kart and have some driving experience. If so, I suggest you drive your friends kart and have him drive yours.
If you are happy with the way your kart handles and your friend says it is tail happy that is a clue to the problem. Also, if you jump in his kart and find yourself chasing the back end all over the track that will help confirm that there is a setup problem on his kart.
Cheap way to gather some useful data before doing anything that cost money or time.
Steve O'Hara |
Aaron Bunch
Posted: Wed Oct 10, 2012 5:59 am Post subject: |
| Steve O'Hara wrote: | Ace,
Steve O'Hara |
Best advice ever.
I am new to karting and basically jumped into a stock moto shifter (02 Tony Kart Mitox) after about 60 laps with a Rotax. It was (is) a steep learning curve. When I got to a point that I thought the kart might be holding me back or the setup needed changing I asked a more experienced driver to try my kart. He immediately posted times 2 seconds faster than me. It was a hard pill to swallow, but at least I am fixing it with track time.
Aaron |
Posted: Thu Oct 11, 2012 11:53 am Post subject: |
I think I did give you some help.
The remark, as you call it, was from my personal observations from over 40 years of karting. I've seen allot of guys with more money and machismo than driving skill get into a high powered kart then present a danger to others.
I don't like it, I think there should be a ladder system where you spend the first year or two in a 100cc piston port kart but, that's how it is.
I only know him from your description as someone who is having tremendous difficulty on practice day and doesn't yet compete on race day. Am I to believe his driving skill greatly exceeds his ability to dial in a chassis? Hmm a rare case indeed.
If you're wondering about my driving credentials I've got trophies and 4 driving championships but, my best awards are the thank you letters and gifts I have gotten from people and track organizations thanking me for helping out. Mostly I end up helping others wrench and operate their karts and I have mentored many people getting started in karting.
I really don't care what you think when your abbreviated insults over the internet are so out of line. Good luck getting help for your friend.
Ace Rossi
Posted: Thu Oct 11, 2012 12:10 pm Post subject: |
And I'm supposed to be impressed? I would think someone with "trophies" and "FOUR" championships would have a lot better Internet politeness but I guess not!
And ONLY 40 years? I'm 60 and I started racing karts when I was 9. Do the math! Oh and I too have Four State championships won in Md., De., Va., and W.Va.
I've raced Summit Point, Daytona, Poconos, Roebling Road and tracks you've never heard of like Marlboro Raceway and many sprint tracks the out the NE like Batavia in NY and the winternats every year in Barnesville where I finished 5th to people like Kathy McCullough better known as Kathy Hartman wife of John Hartman. I've raced with Lake Speed, Ricky Rudd, and Mark Dismore!
Does all this make me special? Heck no! Does it make me a know it all? Nope! Thats why I'm asking for a little help rather than rude replies!
Yes I CAN drive a kart too but theres always room to learn unless your you!
Have a great day and yes, we WILL figure ut out even without YOUR help! |
