MaxSpeed - LB
MG Tires - SS
Best way to clean a fuel thank
Cesar Rull
PostPosted: Fri Oct 05, 2012 4:12 pm    Post subject: Best way to clean a fuel thank Reply with quote
I have tank for my recently purchased kart. I have not idea what kind of fuel the previous owner ran and there is some still in it (very little). It smells like alcohol. I want to dump it out and clean the inside so when I put the normal the fuel I plan to use it all good.
If I wash the inside with dish soap and water and let it air dry for a few days, should it be okay?
Mike Goebel
PostPosted: Fri Oct 05, 2012 4:55 pm    Post subject: Reply with quote
Just pour it out and add your fuel.
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Ken Schilling
PostPosted: Sat Oct 06, 2012 9:49 am    Post subject: Reply with quote
You can use some plain fuel or pre-mix that you will use, pour some into the fuel tank, slosh it around a bunch, then pour out.
Do not use dish soap!!!
Ken Schilling
SKUSA Data Administrator
Cesar Rull
PostPosted: Sat Oct 06, 2012 7:45 pm    Post subject: Reply with quote
Great,
I appreciate the responses.
PostPosted: Tue Oct 09, 2012 10:07 pm    Post subject: Reply with quote
Don't worry about cross contamination just make sure there's no dried oil goop in the bottom that can break loose and clog things up. If the fuel line is hard as a rock get some new Tygon tubing.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Greg Lindahl
PostPosted: Wed Oct 10, 2012 10:45 am    Post subject: Reply with quote
HOT water and 409/Simple Green mix and shake and sit. Set in sun to dry. Cleans tanks very well. I do this every winter with the side benefit of making my garage smell cleaner.
DB time: 0.13447 (42.42%), total time:0.317016, queries:38
