Margay Racing
Tony Kart/Vortex - FB
Cylinder Manufacturing
Sam Moss
PostPosted: Fri Oct 05, 2012 3:03 pm    Post subject: Cylinder Manufacturing Reply with quote
After a long time lurking here I thought I'd best join.
Not the simplest of questions but does a cylinder design like we use in karts and motorcylces have to be a sand cast or can it be fully machined from billet Question
If it can't be fully machined from a billet in could you say machine it to a 70mm bore to mill all the port edges on a CR250 cylinder and sleeve it to create the inner walls of the ports Question
Sam Zavaglia
PostPosted: Fri Oct 05, 2012 3:59 pm    Post subject: Reply with quote
Can any CNC machine make the exact porting angles and water jackets required from a single piece of billet?
www.samzavaglia.com
Greg Lindahl
PostPosted: Fri Oct 05, 2012 4:15 pm    Post subject: Reply with quote
Mill the ports from the outside and cover the holes with a 360 degree collar.
Sure, you could make cylinders. You could also have them built additively as was done by at least one 125 GP team until this year.
PostPosted: Fri Oct 05, 2012 5:38 pm    Post subject: Reply with quote
http://www.cnczone.com/forums/i_c_engines/139166-custom_billet_2-stroke_cylinder_build.html
Wonder how he made out......
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Sam Moss
PostPosted: Sat Oct 06, 2012 11:33 am    Post subject: Reply with quote
How do you mean additively? Confused
Chris that is pretty much how I'd imagined it by milling the outside port walls and using the sleeve to create the inner walls.
My wondering was how important is the inner wall shape? Is it just used to separate the ports from the main bore or is the design more complex and used to guide the fuel towards the outer edge of the ports.
PostPosted: Sat Oct 06, 2012 2:54 pm    Post subject: Reply with quote
Your 2nd answer!!! The transfers are design to push the charge back and down. From my understanding it's to counteract the exhaust flow going out the cylinder, the higher up in the rpm it operates, the more exaggerated the direction.
The post is from this year, I would register on that site and send that guy a message...
CR
james jackson
PostPosted: Sat Oct 06, 2012 6:21 pm    Post subject: Reply with quote
It is possible to rapid prototype cylinders in AL. It has been done before on moto gp bikes back in the late two stroke days on the BSL.
Greg Lindahl
PostPosted: Sat Oct 06, 2012 7:29 pm    Post subject: Reply with quote
Sam,
Three-D printing is called additive manufacturing, usually used for prototyping but new processes allow the parts to be used. CRP does this. Check out this link.
http://www.crptechnology.com/sito/en/news-archive/1316-additive-manufacturing-service-and-windform-materials-for-us-market.html
PostPosted: Sat Oct 06, 2012 8:53 pm    Post subject: Reply with quote
I was in Penske South shop in Mooresville, 6 or 8 years ago, my buddy is a chassis engineer. At that time they using 3D printers to grow foam plugs that were to be sprayed with a ceramic and then used for an investment casting. They also built plastic intake and cylinder runners with another 3D printer for analysis.
So I imagine that's how you could build a cylinder.....
CR
DB time: 0.063291 (38.96%), total time:0.162433, queries:38
