IKF Region 7 - LB
Top Kart USA - SS
Tony Kart/Vortex - FB
hubs
DAVID DAMON
PostPosted: Wed Oct 03, 2012 2:57 pm    Post subject: hubs Reply with quote
I have a shifter kart and has hubs on front with 58mm center of stud to center of stud.Meteric are 50mm center of stud to center of stud.I would like to know what they to get spares.
Thanks Dave
Bill Schmidt
PostPosted: Thu Oct 04, 2012 9:05 pm    Post subject: Reply with quote
We need more info: Age of kart, brand of kart, are hubs original to this kart?
Bill Schmidt
'88 Red Devil F500 4-link rear (Rotax)
Joe Ricard
PostPosted: Fri Oct 05, 2012 5:02 am    Post subject: Reply with quote
Since I am a newb as well please excuse me if I am wrong. BUT
there are only two different european hubs the standard 3 5/8" spacing measured as you do. and then the much larger CRG pattern.
I used to have some standard hubs on my son's kart (old invader) no idea on the spacing. but it was not 3 5/8"
Arrow AX-8/ Rotax Sr.
DAVID DAMON
PostPosted: Fri Oct 05, 2012 2:04 pm    Post subject: Hubs Reply with quote
Have no idea what these are off?????all I can tell you they fit a 40mm spindle and the studs are 58mm center to center.
Bill Schmidt
PostPosted: Sat Oct 06, 2012 6:58 am    Post subject: Reply with quote
There is no such thing as a 40mm spindle. I know of 3 sizes: 5/8", 17mm, 25mm.
Bill Schmidt
DAVID DAMON
PostPosted: Sat Oct 06, 2012 12:27 pm    Post subject: hubs Reply with quote
NEW IN KARTING ,Sorry about wording ,These hubs have a 40mm bore and studs are 58mm center to center.The standered eur is 50mm center of stud, to center of stud.
Steen Carstensen
PostPosted: Sat Oct 06, 2012 12:53 pm    Post subject: Reply with quote
Standard metric front hubs will have a 40m/m bore, and a 40m/m spigot onto which the wheel is located and they are held together using 3 studs and nuts spaced on a 58 m/m bolt circle.
CRG front hubs will have a 40m/m bore and a 55m/m spigot and 3 studs spaced on a 67 m/m bolt circle.
Bolt circle and center to center measurements are not one and the same.
So in my humble opinion, what you have is CRG hubs.
Hopes this helps you out. Very Happy
DAVID DAMON
PostPosted: Sun Oct 07, 2012 5:06 am    Post subject: hubs Reply with quote
Anyone have a CRG hub they can tell me what it measures center of stud to center of stud?????
PostPosted: Sun Oct 07, 2012 8:39 am    Post subject: Reply with quote
http://www.cometkartsales.com/store/wheels/vankhubs.htm#40
Look at the diagram....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
DB time: 0.19598799999999 (51.12%), total time:0.383421, queries:38
