DID Chain
Ribtect - SS (non-flash)
2001 jolly kart?
Ty Schuring
PostPosted: Tue Oct 02, 2012 7:51 pm    Post subject: 2001 jolly kart? Reply with quote
I bought this kart for 300$ all I know is it's a 2001 jolly kart made in Italy. I just got a wka legal clone I know this is a 2 stroke forum but before I had the kart it had a kt100 So any info is appricated.
Here are some pics
http://m1068.photobucket.com/albumview/albums/customshifter/Mobile%20Uploads/IMG_6430.jpg.html?o=15
Ty
Anyone can drive a fast car, few can drive a car fast.
PostPosted: Wed Oct 03, 2012 10:20 am    Post subject: Reply with quote
Make sure the brakes work. Usually on a euro kart the bar behind the seat will interfere with the drive chain on an inboard drive clone motor. What's wrong with leaving the KT100 on it?
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Ron Dodson
PostPosted: Wed Oct 03, 2012 12:01 pm    Post subject: Reply with quote
I run a Jolly Kart with a Clone. Fits fine.
Ty Schuring
PostPosted: Wed Oct 03, 2012 3:30 pm    Post subject: Reply with quote
Unfortunatly the kt100 wasnt for sale with the kart, is it a good kart and do you guys have any info about it?
Ty Schuring
PostPosted: Wed Oct 03, 2012 7:31 pm    Post subject: Reply with quote
Any1?
PostPosted: Wed Oct 03, 2012 7:50 pm    Post subject: Reply with quote
A kart is a kart, they're all about the same. Set your toe straight ahead. What do you want to know, have you been on track with it?
Gif Cool
Ty Schuring
PostPosted: Thu Oct 04, 2012 6:07 am    Post subject: Reply with quote
I have not been on the track with it yet as I am buying a clutch this weekend but I just wanted to know if it's a "good" kart because I can't even find any info on it.
PostPosted: Thu Oct 04, 2012 5:11 pm    Post subject: Reply with quote
Jollykart's a good kart. Like I said just bleed the brakes real good with dot3 and make sure you've got a firm pedal. Make sure the chain guard covers the clutch good and will protect your arm from chain slap. Also check the tires for dry rot and make sure all the wheels spin free. Check all the nuts and bolts around the kart especially the steering stuff. If the toe is straight ahead and it rolls nice and straight on a flat surface you should be good.
Gif Cool
PostPosted: Thu Oct 04, 2012 5:41 pm    Post subject: Reply with quote
Haven't seen a Jolly in a few years, but a friend had one when I was younger and it seemed to go alright in the lower horsepower classes.
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Ty Schuring
PostPosted: Thu Oct 04, 2012 10:32 pm    Post subject: Reply with quote
How do I check to see that the toe is straight?
PostPosted: Fri Oct 05, 2012 8:25 am    Post subject: Reply with quote
Just center up the steering then take a flexible tape measure and check in between the tires front and back.
Brian Mead
PostPosted: Fri Oct 05, 2012 8:26 pm    Post subject: Reply with quote
Ty- make sure the motor mount fits the tubing of the kart. measure the tubing diameter ,it could be 28/30 or 32 mm. If its the wrong size it won't clamp down firmly on the tubing. Jolly karts were made by a world champion karter nicola gianberti (sp?) who won the championship on a Hasse kart in the mid nineties. Imported by a family in Wisconsin, did well. Check the welds for cracks, should be fine for you to run.
Ty Schuring
PostPosted: Sat Oct 06, 2012 9:54 am    Post subject: Reply with quote
Isn't the difference between the 28 and the 32 petty significant? The 28 is for low hp and the 32 is for rotax/shifter and kt100?
DB time: 0.16098 (43.9%), total time:0.366706, queries:38
