2D2W - LB
Installing a spade connecter to M3 RPM wire - will it work?
Spencer Uzri
PostPosted: Sat Sep 29, 2012 11:26 pm    Post subject: Installing a spade connecter to M3 RPM wire - will it work? Reply with quote
I was thinking of installing spade connector on the M3 box RPM wire so that I can quickly disconnect it when removing the engine in lieu of either unplugging it from the box or unwrapping it from around the ignition wire. Question is, would doing so possibly inhibit or disrupt the signal?
PostPosted: Sun Sep 30, 2012 5:11 am    Post subject: Reply with quote
Or you could get one of these...
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Spencer Uzri
PostPosted: Sun Sep 30, 2012 11:01 am    Post subject: Reply with quote
Chris,
Wouldn't I still have to unwrap the line from around the ignition wire with that piece?
PostPosted: Sun Sep 30, 2012 12:17 pm    Post subject: Reply with quote
Yup, you're right.... sorry I was thinking that the wire was just attached to the clip.... I guess you could use a connector, but I think you would need a low loss connector. It's not picking up much of a signal from the plug wire.
CR
Oscar Biondi
PostPosted: Sun Sep 30, 2012 4:50 pm    Post subject: Reply with quote
I've used it with the wire just attached to the clip and it works fine. This was with a pre-09 Leopard ignition if it makes any difference.
Greg Lindahl
PostPosted: Sun Sep 30, 2012 4:58 pm    Post subject: Reply with quote
A spade connector is just fine. Just be sure to crimp the connector well and keep it clean.
John Mulvihill
PostPosted: Sun Sep 30, 2012 5:56 pm    Post subject: Reply with quote
I only wrap around the wire once, not the three times shown. Only takes a second to attach and remove.
John
I bowl overhand..........
joseph hollinger
PostPosted: Mon Oct 01, 2012 11:35 am    Post subject: Reply with quote
John
I don't wrap it at all. Works fine. It's just an antenna.
Spencer Uzri
PostPosted: Mon Oct 01, 2012 12:23 pm    Post subject: Reply with quote
If there's no need to wrap the wire it then that clip would work fine. Is AIM the source for it?
PostPosted: Mon Oct 01, 2012 3:34 pm    Post subject: Reply with quote
That's what I said.... Laughing Laughing Laughing Laughing Laughing Laughing
CR
DB time: 0.132274 (40.09%), total time:0.329982, queries:38
