Italian Motors - LB
K1 Speed - SS
KG Plastics - FB
Mychron 4 mapping problem in RS2
Dan Rudd
PostPosted: Wed Sep 26, 2012 5:03 pm    Post subject: Mychron 4 mapping problem in RS2 Reply with quote
Apparently a setting has been inadvertently changed in my Race Studio program or on my Mychron 4 because when I try to create a new map in RS2 it tells me I can't because the lap is shorter than 33 feet.
I've poured over it trying to find th problm but it's got me stumped. Any thoughts?
Dan
robbie yeoman
PostPosted: Thu Sep 27, 2012 8:59 am    Post subject: Aim Insight Reply with quote
It appears you have no distance calculation. Have you changed your set-up recently? Do you still have speed as a channel in your data? If there is no speed there can be no distance. If the speed is there then check your reference speed in Race Studio Analysis. (Open test and use menu dropdown "Modify" then select Reference speed and use the appropriate speed channel)
If you have any issues give us a call at (800)718-9090
Best,
Robbie@AIM
DB time: 0.229999 (56.7%), total time:0.405607, queries:38
