jeremy shaw
Posted: Tue Sep 25, 2012 6:51 pm Post subject: coolant |
| Sorry guys again for beginner questions. The manual says to use a mix of distilled water and coolant compatible with aluminum......at the track I'm racing on Saturday you can only use water....this ok for engine? Should I be checking coolant and temps more regularly? |
Nick Weil
Joined: 18 Jul 2001 Posts: 1797 Location: United States, Florida, Orlando, FL US of A
Posted: Tue Sep 25, 2012 7:15 pm Post subject: |
Water only is actually required at most tracks and will not damage your motor. HOWEVER, you should use DISTILLED WATER or the minerals in tap water can attack the aluminum and leave deposits, as well as eventually destroying the springs on your water seals and causing premature engine rebuilds due to a leaky water seal. _________________ Nick Weil
Want to save money AND grow the economy? www.fairtax.org |
Justin Martin
Always use distilled water first off. It will rust LESS. Secondly double check to see if they allow ANYTHING. Some tracks often allow water wetter because it isn't anything like normal antifreeze. Much less slippery and gummy. Often a radiator spill with water and water wetter evaporates similar to water alone, not nearly as bad as antifreeze or other coolant.
However just go by what the track wants!!  |
Joe Ricard
Joined: 23 Jun 2009 Posts: 872 Location: United States, Mississippi,
Posted: Wed Sep 26, 2012 4:36 am Post subject: |
Straight water cools better than mix with glycol anyway.
Water wetter does help and also contains enough lubricant to help the seals last a bit longer. _________________ Arrow AX-8/ Rotax Sr. |
