Russell Karting - SS
rotax fuel
Goto page 1, 2, 3, 4  Next
jeremy shaw
PostPosted: Mon Sep 24, 2012 9:35 am    Post subject: rotax fuel Reply with quote
first post coming....just got a great deal on a rotax with a monza chassis.....anyways he said he ran it on 91 pump gas and a 2 stroke mixture of 33 to 1. Looking at manual it says RON 95. So what gas am i supposed to run?
Keith Buffo
PostPosted: Mon Sep 24, 2012 9:46 am    Post subject: Reply with quote
A Rotax loves 93 (pump is fine). But the real answer is whatever the rules dictate where you race.
Keith Buffo
http://BondedTransmission.com
http://CFMotorsports.com
http://DRT-Racing.com
http://OhCopyboy.com
http://www.NHKA.net
jeremy shaw
PostPosted: Mon Sep 24, 2012 10:02 am    Post subject: Reply with quote
its just at club level they dont care about that.... they run 100's, tag and shifters in one class (there is only like 10 people that come) and im gonna be running it at scca events.......but in my area we only have 91....so is it find to run it off pump gas or is it better just to buy it from a auto store?
Nick Weil
PostPosted: Mon Sep 24, 2012 11:56 am    Post subject: Reply with quote
Anything less than 93 and you will run the risk of detonation at higher RPM's as the fuel will want to 'burn' before the ignition actually takes place. I wouldn't risk it, but you said you were also going to be running 33:1 which is a lot more oil than the 50:1 most Rotaxians use.
Nick Weil
Want to save money AND grow the economy? www.fairtax.org
jeremy shaw
PostPosted: Mon Sep 24, 2012 7:20 pm    Post subject: Reply with quote
so 50:1 is the way to go? the manual i got from the person i bought kart has it crossed off and 33:1. Most of the guys run the fireball they are running 7:1 that's crazy.
Nick Weil
PostPosted: Mon Sep 24, 2012 8:51 pm    Post subject: Reply with quote
Most guys running FireBall's are going to buy multiple engines before you rebuild your Rotax once... LOL. In reality, they are probably running 7 Oz. oil to 1 gallon of fuel. NOT 7:1. You should be running between 2.5 and 4 oz. per gallon depending on your jetting and results of quality plug checks and carb settings.
Nick Weil
Thom Andresen
PostPosted: Tue Sep 25, 2012 4:17 am    Post subject: Reply with quote
Commercial grade pump high test fuel doped with 10-15% Ethanol is not advised.
I spend my money on hunting, racing, women, and whiskey - the rest I waste.
Joe Ricard
PostPosted: Tue Sep 25, 2012 4:34 am    Post subject: Reply with quote
Our brand new track just got the under ground fuel tanks installed.
Just like a regular gas station buy with credit card. except you can buy 110, MS98, and real gas 93. It's so easy to walk over and buy an extra gallon of gas to get you through the day.
Arrow AX-8/ Rotax Sr.
Justin Martin
PostPosted: Tue Sep 25, 2012 5:39 am    Post subject: MS93 Reply with quote
For breaking in and or Racing I use MS93 VP race fuels, otherwise I use 100 octane pump gas.
I have been told to run either of these two multiple times by many hardcore rotax guys
Joe Ricard
PostPosted: Tue Sep 25, 2012 8:34 am    Post subject: Reply with quote
That's odd for a spec motor with minimum squish numbers, a combustion chamber that is not allowed to be changed, pipe is spec length and shape. port timing is spec.
What are we missing that 100 would make more power than 93 gas.
Rich Hays
PostPosted: Tue Sep 25, 2012 11:07 am    Post subject: Reply with quote
we have run 91 octane pump gas mixed @ 32:1 (Motul and XPS)for years with no hint of detonation.
-rh
Nick Weil
PostPosted: Tue Sep 25, 2012 11:33 am    Post subject: Reply with quote
You're not missing anything, in fact your wallet is about $3-$6 per gallon better off. Laughing
Nick Weil
Justin Martin
PostPosted: Tue Sep 25, 2012 12:49 pm    Post subject: Reply with quote
Hmm really? I did not realize that. It was my understanding there would be an advantage, and everyone else around here thinks the same
John Savage
PostPosted: Tue Sep 25, 2012 3:42 pm    Post subject: Reply with quote
In racing engine terms the Rotax is a low compression motor and high octane fuel will just be wasted, save some money and just buy regular pump gas - provided your rules allow Wink
Jeff Salak
PostPosted: Tue Sep 25, 2012 5:33 pm    Post subject: Reply with quote
Most Rotax class rules will want you to use VP Motorsport 93. The spec Rotax fuel is this and its unleaded.
VP Motorsport 98 Leaded was once a popular choice too.
Here is the link to VP karting fuels.
http://www.vpracingfuels.com/page469676.html
Page 1 of 4
DB time: 0.126318 (37.22%), total time:0.33939, queries:38
